Results 1 to 15 of 17
Thread: Suggestions for trailer w/ 2016 GTLE
    Mar 2017
    Lexington KY
    I am looking for suggestions for a trailer to pull with my 2016 GTLE. I just don't have the room I need for multiple day trips. Any help for this novice would be appreciated.
    Thanks,
    Brian
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Are you riding two up with camping gear?
    Lee
    2016 R1200RS
    MOA # 30878
    Registered User tourunigo's Avatar
    Aug 2005
    Larry's River, Nova Scotia, Canada
    Uni-go is a good medium-grade option. No matter your riding style it is right there with you on the same track. My wife and I are 10 days away from a coast to coast and back home run with ours (10,000 +/- miles). It has about 40,000 miles on it now so lots of life left. - Bob
    Bob Weber
    saltyfogriders@gmail.com
    Larry's River, Nova Scotia, CANADA
    Mar 2017
    Lexington KY
    2 up with extra gear
    Mar 2017
    Lexington KY
    Quote Originally Posted by tourunigo View Post
    Did it trailer okay at higher speeds with such a small wheel?
    Aug 2005
    Quote Originally Posted by cusunday View Post
    Fastest we had it was 100 mph (two up) down in Nevada somewhere a few years ago. We wanted to test the high speed characteristics at the time. All was fine at any speed. However, that was just a test. Mostly the 70 lb trailer will be holding about 40 lbs of gear and moving at usual traffic velocity. Nothing abnormal when quickly passing. Small wheel is fine and doesn't seem smaller than most motorcycle trailers. Essentially you have an eleven foot (approx) three wheel motorcycle. I have had it operated in some severe (read "pucker moments"), again two up with a load, and it performed to our greatest advantage. However, it is vital to have the correct hitch that will resist twisting motion. Very critical. High speed is not where you will need the most practice. Very slow speed practice i.e. creeping traffic or slow parking lot turns and backing are the two elements requiring the most attention. But once comfortable in the practice, it really just becomes a longer motorcycle. One more thing, it is important to load not only the trailer but the bike/trailer combo (like life) with a keen eye to balancing the load.
    Feel free to PM me or stay on this post with any questions about trailer construction and performance. - Bob
    Bob Weber
    Astatula, FL
    Bushtec
    I would check out the offerings from Bushtec. They have been around a long time and have a great reputation.
    Bob Weis
    Bikeless! 2004-bmw-k12rs-hannigan-Sold!
    Mar 2017
    Lexington KY
    Thanks Bob I appreciate the insight.
    Registered User story's Avatar
    Sep 2013
    Redding, Ca.
    I tow a Colorado trailer from Champion sidecar. http://championsidecars.com/products/trailers/
    Got it in 03 along with my 02 Goldwing. After switching to the K16gtl I had it repainted to match. We've put many thousands of miles on it. Never had a problem with speed behind the Goldwing. I need to make some changes to the hitch or the trailer for high speed towing behind the BMW. The ball is a little high, raising the front of the trailer a little and causing it to want to fly when we get up around 85 mph.
    Enjoying life in the beautiful state of Jefferson
    2013 K1600GTL : 2004 VTX1800c : 2007 K1200GT with Hannigen sidecar
    Nov 2011
    Central Ohio
    Quote Originally Posted by story View Post
    Lower rolling resistance should help your gas mileage!
    Larry
    2006 R1200RT
    May 2006
    Waconia, MN
    Unigo Experience Here
    Towed a Unigo for 8 years behind my 2 K1200LTs - no issues.
    Just a reminder for any bike trailer take the heavy stuff out of the bike and put it low in the trailer. Less weight on the bike better suspension response.
    Unigo can be wheeled into your motel room if you are not a camper.
    Unit can be ordered with luggage bags and a tool kit bag.
    Mine had a Bra - not sure they sell them anymore.
    To hook up brake and turn signals not an issue on an LT but you will need to pay special attention on the K1600 with Canbus for any trailer.
    I swear I got a bit better mileage when towing due to the taper effect of the Unigo trailer.
    Good luck in your search . . . that's half the fun!!
    Aug 2005
    Quote Originally Posted by Dan Finazzo View Post
    All excellent points. Did not much care for the luggage... good quality though. Our trailer mostly used for camp gear...as you say real weight "low in the trailer". As a related point: do not put all of your weight in the trailer (especially if riding one up)..... spred it around (stem to stern and side to side). Balance. Backing the trailer, when done without 'issues' (i.e. 45 degree twist and locking up can give you a bit of a scare) is something to be proud of.
    Again, good points indeed. - Bob
    Bob Weber
    Jul 2016
    Embrun, Ontario, Canada
    Gypsy Scarab Trailer
    I pull a Gypsy Scarab trailer with my 2015 GTLE and have recently returned from a 26 day and 8000 mile trip across the US and Canada; the trailer has plenty of storage and pulls very well behind my bike. I got lots of complements on the style and shape from everyone. Highly recommended.
    Registered User millsaps2's Avatar
    Oct 2016
    Anderson, SC
    Pull behind Trailer
    https://theusatrailerstore.com/pull-...ycle-trailers/
    Try the USA Trailer store. I pulled a Bushtec trailer for several years with a FJR1300 without any problems. The Bushtec trailer is near $5000 whereas the USA trailer is about $2500. I just bought a 3-rail Kendon knockoff for $1800, the Kendon is about $4000.
    Biker gunnert's Avatar
    May 2008
    Catlett, VA
    Unigo Trailer
    After years of fighting over loading I've recently purchased the Unigo. I never considered a 2 wheel trailer, didn't want to be limited in the corners. Hard to tell the Unigo is back there even when running fairly aggressively in the twisties. The Unigo has a lot more room then you would think.
    NoVA
    '12 K1600GT
  1. Replies: 9
    Last Post: 03-14-2017, 11:02 PM
  2. Traded my 2016 RT for a 2016 GS
    By rtsteve in forum Wetheads
    Last Post: 10-21-2016, 03:35 AM
  3. I need muffler suggestions for 2016 R1200RT
    By floridagator in forum Wetheads
    Last Post: 07-25-2016, 08:48 PM
  4. GS-911 use on 2016 RT
    By GRLambert in forum Wetheads
    Last Post: 01-24-2016, 01:24 PM
