Results 1 to 5 of 5
Thread: Cam thing
    Jan 2016
    Central Illinois
    Cam thing
    1994 R1100RS: 77000 miles replacing old17 mm cam chain tensioner have throttle body out of way got socket and small ratchet on it nothing very tight cheater bar with aluminum threads seems not right what next.
    Feb 2005
    Trinity, NC
    That space is so tight. It's hard to believe you really got a ratchet and socket on that 17 mm hex head. Try it with a 17 mm wrench. 1/6 turn at a time. If it really won't budge try a little heat on the hex head. It should come out.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Registered User lowndes's Avatar
    Apr 2016
    Roswell, GA
    17 box end wrench and a rubber beater. An open end won't fit enough to get a good purchase on it. No thread locker on either of the '99 OEM tensioners I've replaced. And mine weren't that tight. The new one is much easier with the smaller hex. Don't forget you have to compress the spring in the new unit about 1/2 inch to start the threads. A long flat blade screwdriver in your left hand works well for this. No way to torque it properly so you might consider a thread sealer on the washer. It's not a service item so you won't need to be getting back in there unless it's something major.
    Jan 2016
    Central Illinois
    Success
    Got thing broke loose and out now for the new one.
    There is a rubber hose runs down right next to left side cam tension thing goes in bottom of engine goes up to what looks like cyclone separating thing, big hose on top goes into cone thing, hose is oil soaked at bottom should I do something or ignore?
    Quote Originally Posted by 179212 View Post
    That cyclone thing separates oil from oil mist and returns it by hose back to the sump. If it is wet that hose and or the clamps need to be replaced.
  1. Got another RT Good thing, ESA Stuck BAD Thing...
    By PCHRT in forum Hexheads/Camheads
    Last Post: 11-20-2015, 08:59 PM
  2. So what do we name this thing?
    By ka5ysy in forum Straight 6 K1600 GT/GTL/B
    Last Post: 02-08-2011, 02:44 PM
  3. Does anyone know what this thing is? K75
    By GREGFUESS in forum Flying Brick K-bikes
    Last Post: 12-23-2010, 03:41 PM
  4. Replies: 39
    Last Post: 11-17-2005, 06:39 PM
