My 1978 R100/7 was not charging the battery. I did some researched and I believe the ignition rotor is bad. When checked for resistance I was getting a 0 reading. The alternator contacts looks pretty corroded so I will clean those up but I guess the question I have to get this conversation started is, how does the wrapped wire on the rotor go bad? It looks like it has some type of sealant covering the wires. Where does the stress come from to break the wire, if that is what's happening.
