Results 1 to 13 of 13
Thread: Opinions on Givi Top Case
    I just purchased a 2010 R1200RT an would like to get a top case for it. The BMW cases are out of my price range and I was wondering if anyone has experience with Givi top cases. I am looking at the Monokey series. Any help is appreciated.
    Just another rider 61242's Avatar
    Wisconsin
    Quote Originally Posted by gundog94 View Post
    I have a Givi V46 and a Givi Maxia 55 (these are the Monokey series). Both are great top cases, although with the newer Maxia series Givi went to a more "fiddlier/complex/whatever" latching mechanism (IMHO). With the Maxia you need to always double-check that the lid is securely latched. And then double-check again. The V46 uses a very simple latch that is either locked or not.
    I've used both Givi cases on a 2009 R1200RT, F800GT, and a Piaggio MP3 400. I'm about to put a RT-specific mounting plate on a 2010 R1200R (I *think* they use the same rear rack). Givi makes bike-specific mounts and a generic mount. I have a bike-specific mount on the RT and MP3, a generic mount on the F8GT. The difference between the bike-specific mounts on the RT versus GT is the brackets used to secure the mounting plate to the rear rack (the actual case mount is the same).
    I've never noticed any buffeting with either case on any of the bikes, well, except maybe in a strong crosswind. The R1200RT mounting bracket *is* a bit fiddly to install, there are a couple tips/tricks on the interwebs that help (I might have these bookmarked).
    HTH, ask away if you have more questions. And if I haven't made it clear, yes I'm happy with the Givi cases.
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Apr 2008
    Calgary AB
    +1. I have used Givi V46 topcases on my Suzuki VStrom, BMW F650GS and my R1200RT. My cases have been in continuous use by myself since 2006 so do last well without issue.
    Ken Dittrick
    2008 R1200RT (Biarritz Blau)
    Excuses are the rocks upon which our dreams are crushed - Tim Fargo
    Registered User liv2ride's Avatar
    May 2012
    Honolulu, HI
    I have a V47 with the admore LED light kit (running, brake, turn). The quality is better than I expected and the case is not as heavy as you would think it would be, considering the size.
    I would buy this case again without question. Although this is the first top case I have owned, I would shop Givi again if I needed another.
    Fwiw, I fit just about everything in this case that I fit in the two panniers on my '12 RT. My L Shoei Neotec and gloves fit in one side of it and battery jump starter, tire plug kit, inflator and rain gear fit in the other side.
    Sep 2013
    Central Maine
    I also had a Givi Maxia 55 top case, ran it for 100k miles between two different Triumph's, worked flawlessly.
    RK Ryder
    London, Ontario
    I've been using a 50 litre Givi for 12 years on both bikes. It has worked flawlessly. No leaks, easy to lock and unlock. I think that it looks good on all models of BMWs.
    Paul F. Ruffell
    Niagara Riders & Knights of the Roundel #333
    Thanks everyone. This is what I was hoping to hear. Looks like Givi is getting another customer.
    I just put a shad 50 litre case on my 2011 1200RT. I liked the features and looks of the Shad over the Givi. You can see some pics of a setup just like mine here: http://bmwsporttouring.com/ubbthread...074#Post967074
    I have been very happy with it. If you shop around, you can sometimes find good deals on the case on ebay, and Amazon has the best price for the mounting kit.
    Speaking of mounting kit, the Shad comes with a "universal" base. Given some time and ingenuity, one could mount the base to an RT without buying the specialized mounting hardware (which is overpriced for what it is). However, the specialized kit makes mounting the base a snap, and I'm glad I spent the bucks on it.
    I recently added the Shad rack to the case. The price was reasonable, and the install was relatively easy, but it is small, and the mounting spacers and gaskets give the finished product a cheesy look. If nothing else, the rack was worth it for one unintended feature - the added weight to the top of the case keeps the lid open without having to hold it up.
    The givi options for my '12 R1200R were limited to scooter cases, so I ponied up for the BMW one. It was stupid expensive, but I will say that it is very nice. If you are buying Givi, I saved a bundle on my Trekker Outback setup for a different bike by using Motostorm out of Italy and having them shipped to the US.
    Sent from my iPhone using Tapatalk Pro
    RK Ryder
    London, Ontario
    I removed the rear red plastic from my 50 litre Givi top box and then removed the white paper that lay underneath the red plastic. Next I measured and cut some silver reflective tape, the same size as the white paper and replaced the white paper with the reflective tape. Finally reinstalled the red plastic. Now at night, when headlights reflect off of the Givi, the red plastic lights up like red tail lights. No need to wire the top box for visibility.
    Paul F. Ruffell
    I have had Givi cases, both top and side, on several bikes since 2001 and have been satisfied with the quality. The only problem I sometimes ran into was that the mounting brackets seemed to not be drilled properly and having to do a bit of modification. Presently have a V46 on my 2014 R1200R and vary happy with it.
    I had Givi side cases in a two week tour in New Zealand. My only complaint was the need for a key - always - to open the darn things.
    Registered User YeehaStephen's Avatar
    Deep in the Heart of Texas
    I had Givi side cases.... My only complaint was the need for a key - always - to open the darn things.
    I didn't like that either, so I snagged a Coo Case for the top box. No need for a key every time AND it comes with a remote so you can show off!
    http://www.coocase.com/product/s28-vivo-28-litres-6/
    SS
    Yeeha! Stephen
    R1200RS, R1200RT, R1200R, (R1150RT = Donated To Charity)
    "Why eat a Burger when you can have Pie?!" Miss Vicki @ Lost Maples Cafe - Utopia Texas
  1. Givi Top Case Question
    By leadfoot in forum Gear
    Last Post: 09-23-2008, 06:23 PM
  2. LED lights on Givi case
    By 139679 in forum Gear
    Last Post: 04-16-2008, 12:32 AM
  3. GIVI Top Case......I am Scared!!!!!!!!!
    By buckeyeclark in forum Oilheads
    Last Post: 04-03-2008, 05:27 PM
  4. Givi top case lock
    By Jfixit in forum Gear
    Last Post: 10-22-2007, 01:12 PM
