Results 1 to 15 of 16
Thread: Cyclops LED Bulb Replacement
    Left Coast Rider
    If any of you noticed what looked like a nuclear flash in the Pacific Northwest this afternoon, don't fret - its just the new high beam on my bike.
    Based on the experience and postings of "lowndes", I ordered the H7 replacement unit for my S. Received and installed today. Installation is as simple as replacing the standard bulb. But the results are, in two words, "HOLY SH*T!"
    I can't wait to go for a ride when the sun goes down. And if I run into any Left Lane Louies (or Louises), they'll be getting the paint on their trunk blistered.
    Registered User lowndes's Avatar
    Apr 2016
    Roswell, GA
    Ha!!
    If you really want to have some fun, put a modulator on it.
    The real test will be time this LED lasts.
    "We'll see."
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Quote Originally Posted by lowndes View Post
    Ha!!
    "We'll see."
    The real test would be to record the lumen output at regular intervals from new.
    I was amazed at the output reduction over 4 years with my hid low beam. The new lamp was noticeably brighter.
    Output lumens had dropped almost 30%
    Ufda happens..........
    Registered User krash's Avatar
    Aug 2016
    Connecticut a.k.a. hell
    Ive had the Cyclops since last year...one of the best upgrades I've done...it's a flame thrower at night...
    1999 R1100R
    "Big Blue"
    Gerard jagarra's Avatar
    Aug 2016
    Reno, NV
    Did you get the 3800 lumen or the 7000 version.
    1994 R1100RS-(5/93)-,1974 R90/6 built 9/73,--1964 Triumph T100--1986 Honda XL600R
    Left Coast Rider
    Quote Originally Posted by jagarra View Post
    4,000 lumens.
    I think that equates to a zillion candlepower.
    http://www.cyclopsadventuresports.co...Bulb_p_86.html
    4000 lumens / 12.57 = 318.21 candlepower
    Left Coast Rider
    That being the case, what would be the candlepower of the stock headlight - 27 ?
    H7 Incandescent - 1450 lumens / 12.57 = 115.35 candlepower
    Left Coast Rider
    Wow, the new bulb is 275% brighter. That's a number worth knowing.
    RK Ryder
    London, Ontario
    What bulb did the Cyclops LED Bulb replace? Hope that it could be a replacement bulb in my bikes.
    Paul F. Ruffell
    Niagara Riders & Knights of the Roundel #333
    Apr 2016
    Roswell, GA
    Hey, Paul_F,
    The Cyclops is just a brand or manufacturer. They have a variety of bulbs for lots of different applications, vehicles. There are a lot of different bulb types, H4, H7, H11, 9005, etc. They vary mostly by the socket or mount in the rear of the reflector. The reflectors all have different pattern sockets that the bulb sits in. In fact most of these LED headlight bulbs are the same with different mounting plates. It makes them much easier to install, too.
    You can look up your bike's bulbs (headlight, brake, turn, instruments, etc) here:
    https://www.superbrightleds.com/vehicle
    They make a dandy little programmable modulator for brake lights for $6.95: https://www.superbrightleds.com/more...mer/1082/2573/
    There is a bunch of info on LES's, canbus etc, too.
    Usually you can select the brightness (lumens) and color of the light (Kelvins) in a bulb type.
    If you decide to get LED's for your brake or turn signals, get the red LED bulbs for red lenses and amber for the amber lenses. Colored lenses block all the light except that color so you might as well make just that color light.
    Left Coast Rider
    I can't add anything to what lowndes has said except to say that I replaced my H7 high beam with this.... http://www.cyclopsadventuresports.co...Bulb_p_86.html
    Not sure which replacement unit you need but if its for your R1100, this thread could be helpful (just scroll down to post #9 where the LED replacement is discussed - with pics!)..... https://forums.bmwmoa.org/showthread...ment-Procedure
    One last thing - the folks at Cyclops Adventure Sports are a joy to deal with.
    RK Ryder
    London, Ontario
    Hey, Paul_F,
    Thank you gentlemen! There is a replacement LED headlight available for each of my bikes.
    Although I seldom ride at night and I do have auxiliary lights, the headlamps on both bikes leaves much to be desired. As well, these should make me more visible to daytime drivers.
    Paul F. Ruffell
    Wow, 275% ! Thats definitely going to get someone's attention!
    Sent from my SM-P607T using Tapatalk
  1. Replies: 5
    Last Post: 10-16-2016, 04:35 PM
  2. Taillight bulb replacement
    By jsf14469 in forum Airheads
    Last Post: 10-05-2014, 11:23 PM
  3. RT Headlight Bulb Replacement
    By bikerboy108 in forum Hexheads/Camheads
    Last Post: 08-08-2012, 07:46 AM
  4. LED light bulb replacement
    By flashman51 in forum Oilheads
    Last Post: 12-02-2008, 04:04 PM
  5. R1200RT Bulb Replacement
    By 108281 in forum Hexheads/Camheads
    Last Post: 08-17-2007, 03:07 PM
