Page 1 of 5 1 2 3 ... LastLast
Results 1 to 15 of 69
Thread: Octane Question
    Octane Question
    Is anyone using low octane fuel in their wetheads? I was riding with someone last week who only uses low octane in his K1200. I know it's a different engine but I wondered if anyone ever gave it a try on their new wethead.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    The manual calls for 89 AKI. If you can't find 89 it wont hurt to use 87 once in awhile.
    The manual say if you use 87 AKI all the time the bike needs to be reprogrammed.
    Lee
    2016 R1200RS
    MOA # 30878
    Apr 2016
    Tacoma Washington USA
    Quote Originally Posted by collesidis View Post
    https://plus.google.com/+JohnSherman2/posts/AmHm7Qj4rk6
    Sent from my SM-G935V using Tapatalk
    John Sherman
    Tacoma WA USA
    2016 R120RT
    Apr 2016
    I use low octane fuel during winter cold months but when I do I don't run engine RPMs higher than 4.5k. Summer higher octane then I will take RPMs to rev limiter stop. Just my theory for my 2016 R1200RT wet head.
    John Sherman
    Tacoma WA USA
    2016 R120RT
    Registered User dabubba's Avatar
    Aug 2006
    Fairbanks, AK
    Higher octane will yield better gas mileage, so in my book it's almost a wash and certainly not worth possibly damaging a very expensive engine. Pay for the high octane if it's available.
    Mike Gray #103649
    2000 K1200LTC
    2014 F700GS
    2016 R1200RT
    Nov 2011
    Central Ohio
    Quote Originally Posted by dabubba View Post
    My Hexhead has knock sensors so I'm not worried about engine damage. Using low octane does slightly lower gas mileage and power, noticeably reducing my passing acceleration. The price difference is not significant in the grand scheme of things, so I use premium exclusively and enjoy the power - that's a part of why I bought the bike.
    I assume the Wethead has some sort of knock management system, but have not heard any description of how it might work. I understand the knock sensor has been eliminated, so without knowing IF the bike is protected against pre-ignition, I'd play it safe and use the specified fuel.
    Larry
    2006 R1200RT
    Northern Front Range, CO
    Quote Originally Posted by johnesherman View Post
    Can you explain your thinking in that decision, as it really makes no sense to me.
    The danger of lower octane fuel is pre-ignition, or knocking. Most likely to occur at lower revs (not higher), in hotter temps (not winter), and under higher load (carrying mucho weight or ascending serious grades.
    Ride Safe, Ride Lots
    Apr 2016
    Well, answer to your question: octane, RPM, & winter, my theory applied. No high RPMs with lower octane fuel used during cold winter riding.
    See generally,
    https://www.hemmings.com/blog/2014/0...-priced-fuels/
    http://www.faqs.org/faqs/autos/gasol...section-1.html
    John Sherman
    Tacoma WA USA
    2016 R120RT
    The question is higher than what? My GS is rated for 89 aki. You might get some knock using 87 but you do NOT get better mileage or anything else from going to 92. The BMW engineers built the engine for 89 and state you can use 87 in a pinch. 92 was never in the game. If you want better mileage get non-alcohol, straight, old fashioned gas rated at 89.
    Old But Not Dead
    Semper Fi
    See generally,
    still leaves me asking that proverbial question "why bother with either limitation- lowered rpm and/or lower octane? to save a few pennies? I know on my '16GS, keeping it under any arbitrary rpm (other than redline) is not an easy task... and certainly not when it's just getting into the fun zone of above 5K.
    i guess that's why they make bagels, ice cream, pie, donuts and pizza in all kinds of flavors... to each his own.
    Apr 2016
    The simple answer: Use the BNW OEM suggested octane fuel minimum rating for entire RPMs use and enjoy the ride
    John Sherman
    Tacoma WA USA
    2016 R120RT
    Registered User kioolt's Avatar
    Maryland
    I was taught many years ago that you should use the lowest octane gas that the engine will not pre-detonate with. This would provide the best fuel economy. This was before knock detectors, ECU's, fuel injection, etc. I was able to find the following to support this.
    "Use the recommended gas for your car. Going lower than the recommended may reduce fuel economy as the engine may have to retard timing to avoid detonation. Going higher than recommended won't help as your engine is unable to take full advantage of it, as well as the fact that higher octane fuels actually contain slightly less energy (they just offer a more controlled burn that higher compression engines can take advantage of)."
    Even more information.
    http://www.fueleconomy.gov/feg/octane.shtml
    2004 R1150RT 183,000 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 418,600 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    Registered User BMARC153920's Avatar
    Dec 2014
    Orange County, NY
    This is not true and has been proven study after study. Google is your friend....If it were true every single car manufacturer would call for super unleaded in every car to help epa mpg requirements.
    Sent from my Pixel using Tapatalk
    Nov 2011
    Central Ohio
    Quote Originally Posted by BMARC153920 View Post
    This needs some clarification. Using higher than specified octane does not improve mileage. But for some engines with high compression ratios like the R1200 in question here, using the specified higher octane DOES improve mileage, because that is the fuel the engine is designed to burn. Using lower than specified octane can produce knock, causing the ECU to change spark timing, reducing power and efficiency.
    Larry
    2006 R1200RT
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    My 2015 LC RT calls for 93. Not sure where all these other numbers come from but 93 is what my bike runs.
    It is listed as this.
    Recommended fuel quality
    Super unleaded (max. 10 % ethanol, E10)
    89 AKI (95 ROZ/RON)
    89 AKI
    Where I live Super Unleaded is 93 10% corn, E10
    If I read it correctly it says the preferred fuel is Super unleaded. Then that the other 2 choices are acceptable substitutes.
    A RT WC has NO knock sensor in it. None! If you hear, or think you hear pinging, you probably are.
    Lee
    2017 R1200 GSW
  1. Octane levels
    By Justscootin in forum Motorrad
    Last Post: 12-13-2012, 11:24 PM
  2. Octane and altitude question
    By glenfiddich in forum Motorrad
    Last Post: 12-06-2012, 11:58 PM
  3. 87 Octane in my 08 RT/Octane Booster Question
    By cookie in forum Hexheads/Camheads
    Last Post: 10-04-2012, 05:30 PM
  4. 91 Octane Vs. 89
    By dohboy in forum Hexheads/Camheads
    Last Post: 12-27-2011, 06:10 PM
  5. Nube question / 87 octane in K100
    By martee99 in forum Flying Brick K-bikes
    Last Post: 07-16-2008, 08:07 AM
