Results 1 to 6 of 6
Thread: Center Stand, any corrosion issues?
    I have a 2015 RT (25,000 miles) and I have noticed that much of the paint on the crossbar of the Center Stand has been worn away. It is obviously an area that will be blasted by road grit from the front tire so I have to believe that this is a normal situation. My question to the forum is whether this part is prone to corrosion and if so, what are some ideas to minimize any issues.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by SeattleRTrider View Post
    I have seen quite a few complaints on the RS forum. I didn't think much of it as most of our bikes have done it.
    In the past I have repainted the cross bar every couple years.
    On my R1200RS I wrapped the cross bar with a clear 3M film.
    Lee
    2016 R1200RS
    MOA # 30878
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    Sand it, mask it, coat it in spray-on truck bed liner.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Simple and straight-forward. Thanks
    Registered User Mark H's Avatar
    Nov 2013
    Sydney, AUSTRALIA
    Hi - my last R1200R suffered a similar issue with the centre stand, so when I got the new R1200GS I went to the local hardware store and purchased a length of 1" thin wall black tube used for watering systems.
    Cut to length and then split it down the centre to allow it to slip onto and around the main cross bar. It's matt black and once fitted is almost invisible.
    Not much help now that you are already seeing the damage, but with a new coat of paint, this will protect it.
    Mark Hubble
    2015 - R1200GS Black Storm Metallic
    Sydney, AUSTRALIA
  1. Replies: 32
    Last Post: 11-09-2015, 02:53 AM
  2. 650CS Center Stand Issues
    By jbernel in forum Scooters
    Last Post: 03-19-2013, 04:54 PM
  3. r90/6 side/center stand issues
    By stewartr in forum Airheads
    Last Post: 07-20-2011, 03:38 AM
  4. R/GS Center Stand Design Issues
    By racer7 in forum Hexheads/Camheads
    Last Post: 09-22-2010, 01:52 AM
