Results 1 to 12 of 12
Thread: R850R Dash lights
    R850R Dash lights
    I am working on a friend's R850R and trying to make it right.
    First, it is a testament to BMW that this goes down the road. It has had multiple owners and I am guessing none have done much beside ride it, drop it, slide it, etc. You get the point.He has put 7000 miles on it and not even changed the oil. Doesn't know how to check it! Never knew there was a center stand. The list goes on but you get the idea
    Anyway, someone put turn signals on it and I thought they were wired wrong. They are wired correctly. The reason I thought they were wrong is because the dash lights for both the left and right signal are illuminated. They come on brighter where your signal but they are on. Are the turn signals also clearance light and are supposed to be on? Is the dash indicator supposed to be on?
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    No there are no clearance lights.
    Look for and open ground.
    Ufda happens..........
    But is the dash indicator supposed to be on?
    Feb 2008
    Quote Originally Posted by tycham View Post
    Not if the turn signals are off.
    That is what I thought so I will have to track it down
    Check to make sure a Kissan Signal Minder or similar has not been added to provide running lights.
    Good point. If I remember right that plugs into the fuse box as a relay
    In place of the original turn signal flasher unit.
    It is a Kissan Signal Minder feature/benifit. Thanks for the answer
    Feb 2008
    Good catch Paul
    Registered User jsouth's Avatar
    Apr 2015
    Weatherford, OK
    But that "feature" can be turned off. I have to remember how every time I disconnect the battery. Details should be on the web. Make sure you hold your tongue just right....
    Quote Originally Posted by jsouth View Post
    Push and hold the turn signal cancel button.
    Then push the emergency 4 way flasher button.
    Repeat a second time.
    The running lights should be off
  1. 85 KRT - fuel level dash lights
    By mneblett in forum Flying Brick K-bikes
    Last Post: 11-17-2010, 03:41 AM
  2. LED dash lights
    By axlray13 in forum Airheads
    Last Post: 06-01-2009, 02:54 AM
  3. k75 dash lights
    By yankeeone in forum Flying Brick K-bikes
    Last Post: 12-12-2008, 09:50 PM
  4. Replies: 9
    Last Post: 04-07-2007, 07:06 AM
  5. Replies: 11
    Last Post: 08-03-2006, 06:08 PM
