If he has so much experience on these bikes, maybe he could share some of it and tell us where the female torx could be found on these bikes.
Harbor Fright tools.
How about the bolts that hold the calipers on. (Front)
What FASTENERS ON THE BIKE, other than the front caliper mounting bolts, require female torx?
What is the difference between a "female torx" and what takes a 12 point wrench or socket?
I went out to the garage to check the header nut, and a 13mm 12 point was a good fit on the R1200RS.
Don't know if this is true for all sizes.
More socket to nut contact area.
The parts fiche shows a female torx nut for the exhaust headers.
My R1200RS has the same nut and my K1300S had the same nut.
. All my Torx sockets have 6 points, so none of those would work on a nut like that. Apparently, it's known as a Triple Square, used mostly by German auto manufacturers. .
