lkchris
Active member
I've often wondered about that. Maybe premium fuel is easier to find outside the US. This is a design consideration that BMW has opted for for some time. In the 70's we got around it by installing cylinder base spacers or dual-plugging heads. Modern engines use knock sensors to retard timing but I have personally seen pistons from a k1600 with broken ring lands.
Higher compression ratios do produce a bit more power and are more efficient but the small percentage increase hardly seems worth it.
It's the classic dichotomy in engine design ... large displacement, slow revving or small displacement, high revving.
Europe has chosen the latter along with really high gasoline prices and taxation based on engine displacement and much consequent concern regarding consumption.
The USA chose for decades the high displacement alternative with low gasoline prices and little to no concern for fuel economy.
The bottom line for gasoline internal combustion engines is that high efficiency and high compression and advanced ignition are inseparable, and, indeed, you won't find many Euro vehicles running "low test" fuels.
It's fairly hilarious IMHO that so many Americans are nearly insulted by a requirement to use high octane fuel, perhaps expecting--in error--that low fuel consumption can occur with low octane fuels and retarded timing. The fact of the matter is that the EPA and the like are in fact studying how to get wider distribution of high octane fuels in the USA. Just know that the concern is consumption, not cost.
It's for sure my opinion but my opinion is also that it's pretty close to fact that in the automotive world Europe is the leader and the USA is in comparison a third world country--see 1950s designs, see bragging that the boat anchor that is the mouse motor is 50 (now 60) years old, see 45-degree V-twins, see "hemis"--and the obsession with low octane fuels is simply reflective of that "good ol' times" culture rather than much understanding of engine efficiency and modern technology. Politicians' unfortunate obsessions with electric vehicles is another story altogether, of course.
