Results 1 to 7 of 7
Thread: 2017 R1200RT Battery
    Nov 2005
    North Conway, NH (winter and summer) and Ormond Beach, FL (spring and fall)
    I just rode my new 2017 R1200RT home and immediately wanted an SAE plug connection to the battery. Took off the battery cover and could not believe how difficult it was to get the battery out and back in. I never did get the cover back on... just stretched the black elastic holder and reconnected that. I am very tempted to buy a smaller battery and use a spacer to hold it in. Any thoughts or suggestions?
    Registered User jswisc's Avatar
    Oct 2016
    Wisconsin
    Battery
    I have a 14' RT and plan on putting in a Shorai lithium. I've used them on my last 3 bikes, over 5 years, without an issue. Usually saves 5+lbs. and is considerably smaller. I bought the Shorai charger as well.
    2014 RT, 2008 Honda VFR, 2003 Ducati 800ss race bike
    Mansfield,MA
    I haven't worked on that bike. I have found that most of the batteries (and tool-kits) are hard to "repackage". I'd leave it alone. You have 2 years warranty on the original. It looks like you are getting ready to use a battery tender- you'll be fine.
    Sometimes warming the wires with a heat gun limbers up the wires and allows them to get back into position.
    Mod Squad
    2009 F800GS 1994 TW200
    Registered User lirider's Avatar
    Oct 2015
    LI, NY
    You don't have to remove the battery to get at the contacts. The negative terminal should be right in front of you as you look at the battery and BMW provides a convenient positive tap just to the right of that. Connect to those two points and you're good to go.
    2016 BMW R1200RT
    1996 Honda VF750C Magna
    1983 Honda CB550 Nighthawk
    Nov 2005
    Ahhhh... I saw that positive post off to the side for jump starting but did not see that I could connect the SAE plug there. Damn. Would have been a lot easier. Thank you, guys for your replies.
    Mansfield,MA
    Quote Originally Posted by 1downfourup View Post
    And a hurricane mt. road ride to you as well.
    Gary
    Mod Squad
    Tucson, AZ, & Madison, WI
    Jeff Dean − BMW MOA Co-founder (1972)
    Tucson, Arizona, and Madison, Wisconsin
    Co-founder, 1972, of BMW MOA -- http://bmwdean.com/r1200rtw.htm
    '17 R1200RT, '15 R1200RT, '67 R60/2, '69 R60US, '55 R67/3, '49 R24
  1. 2017 r1200rt reviews
    By motor4 in forum Wetheads
    Last Post: 06-01-2017, 11:59 PM
  2. 2017 r1200rt and ABS pro, opinions?
    By 22893 in forum Wetheads
    Last Post: 08-17-2016, 05:28 PM
  3. Battery R1200RT
    By bob5025 in forum Hexheads/Camheads
    Last Post: 04-07-2014, 01:35 AM
  4. battery for '07 R1200RT
    By ronboa9 in forum Hexheads/Camheads
    Last Post: 02-26-2011, 02:08 PM
  5. R1200RT Battery
    By TexasEtienne in forum Hexheads/Camheads
    Last Post: 10-20-2007, 10:55 PM
