Results 1 to 3 of 3
Thread: Powerlet in Puig, Now What?
    Apr 2014
    Northern California
    The latest BMW ON had an article on Puig side-panels. I was looking for places to mount a couple of Powerlet sockets and figured that the Puig panels would provide same. Here is the result (if it posts!):
    So far, so good.
    But I must be able to remove the side panels, which means the wires to the Powerlet must include a connector. The Powerlet came with what looks like a Molex connector, which is not weatherproof. I know that is not a big issue for a 12v system, but that area of the bike gets really wet if I ride in rain. So, Seal-All, Weather Pack, and Metri Pack are all weatherproof connectors.
    My question is: does anyone here have actual experience with any of these connectors in a 15A circuit located in a place where they get wet? If so, what worked for you? Or, perhaps more importantly, did any not work for you? Also, did you just squeeze the connectors onto the wires - no solder? That's the standard, so, just wondering.
    Thanks for any input.
    Imported Norwegian Viking viking59's Avatar
    Oct 2015
    South Carolina
    I've got a power let connector on the left side front cover on my 2015 GSA, fused over 15 A. I used two regular female side connector, crimped and soldered the on the Powerlet. The connectors were then completely cover in liquid tape.
    I use the connector for heated gear, 12 V air pump, Tender Junior charger, charging electronics (using a two-output usb outlet).
    2015 Gelände-Straße Abenteuer Wassergekühlt Urban Angriffsfahrzeug
    “Don’t Let The Fear Of What Could Happen Make Nothing Happen.”
    Apr 2014
    Northern California
    Thanks, Viking.
    I've ordered Weather Pack connectors for the job. Hope they work out OK. I feared that using the female Powerlet connectors would limit either panel removal or weather protection (it will be wet under the Puigs on occasion). They claim they their pins need only crimping, but I still wonder about that at 15A.
    I've learned that the Clearwater CANopener has a wire that I can use to trigger my PDM-60, so that eliminates a concern there. (I might have just used a relay and a fuse block if I had known that sooner - but I still value the ability to use the PDM-60 to set a delay on powering up accessories.)
    Your use is about what I have in mind too.
