I need to replace mine on a 2005 K1200S due to road rash. The number on the box is 61357694215. My question is how many of the numbers have to match?
I have 106 818 10; 001 05 22; and 61357694215.
I tracked one down that has 106 818 10 and 61357694215 but 001 05 25. Max BMW shows none of these numbers. The 61357694215 vendor site says it came off a RT Help !!
http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51574&rnd=12082016 is the part page. The K1200S has three 'brain' components. There is a decoder and antenna up at the key, the component that I am questioning receives the signal and does the lights, etc and is located on the left side under the fairing and then the ECU under the seat that handles the fuel and operation of the motor. None of the numbers I posted are casting numbers, the are item specific label numbers
Notic that the only line that does not match is the 001 05 25 instead of 001 05 22. Is that a problem
