Results 1 to 15 of 20
Thread: Abba Skylift - Anyone used this?
    Registered User skibumwi's Avatar
    Jul 2016
    Milwaukee
    I posted this in the Wethead section but wanted to open the discussion up to all riders.
    I'd love to be able to elevate my bike off the ground to make maintenance easier but can't fathom the idea of devoting enough precious garage space to accommodate a lift table.
    http://abbastandsusa.com/product-det...ky-lift&pid=44
    This looks like a good, although spendy, alternative.
    Anyone have experience with this product??
    Ski
    Feb 2010
    Cape Cod, MA
    When I click on this, all I get is a server error.
    John Simonds
    2017 R 1200 GS Adventure
    1975 Norton Commando 850 Roadster Mk 3
    If it ain't broke, fix it 'till it is.
    Southern NH
    Jan 2017
    Southern NH
    link didn't get added correctly (it looks like)
    Does it come with a free CD....or a poster of those two pretty girls......
    Ron Prior {AMA member ,MOA member}
    Milford,Oh
    2002 KLT
    2004 Roadster
    Registered User frenchnew's Avatar
    May 2011
    Prevost (30 miles north of Montreal), Quebec, Canada
    I like you did not like the idea of loosing precious garage floor space for 2-3 days per year so my choice was a Kendon motorcycle lift that can be rolled to the side and standed up when not in use.
    HTML Code:
    https://www.kendonusa.com/stand-up-motorcycle-lifts/
    I had the lift for almost 5 years and still love it.
    2016 K1600GT Cosmic Blue , ABS, ASC, ESAII, TPMS & Alarm, Radio, Sat, GPS Nav V
    Skene IQ150-TS front and IQ 160-TS rear
    CENTEX USA
    Headed to Gear shortly to keep all the lift threads on the same floor
    Steve Henson
    Quote Originally Posted by 71243 View Post
    Tsk Tsk Tsk
    Tsk Tsk Tsk
    I think our age is showing....
    Milford,Oh
    2002 KLT
    2004 Roadster
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Calgary AB
    Quote Originally Posted by frenchnew View Post
    HTML Code:
    What size of bike (weight) can you put on this lift?
    Ken Dittrick
    2008 R1200RT (Biarritz Blau)
    Excuses are the rocks upon which our dreams are crushed - Tim Fargo
    Jul 2016
    Milwaukee
    Took delivery of the Abba Skylift today - First thoughts.
    The FedEx man arrived at 12:30 today and delivered my Abba Skylift less than a week after I placed the order. The package weighed just a touch over 100 lbs. I put the lift together in my un-insulated, lightly heated garage with an outside temp just below freezing. The instructions and videos were very helpful but could use a few tweaks. The quality of the product appears to be quite good, but there are a few issues that I can detail if anyone is interested.
    As you can tell from the following pictures I am not OCD
    Wheelie Position - great for working on the front end -should make installing a new horn much easier.
    Stoppie position - great for working on the rear wheel or adding additional LED lights.
    It also has a Horizontal position - but that's boring.
    The bike can be rolled around in either wheelie or horizontal position, but not stoppie (the front wheel remains on the ground). The lift itself can easily be broken down when not in use and should take up very little garage space.
    The Abba videos show them rolling around a 300 pound sport bike on perfectly smooth concrete with no issues. Having a 600+ pound bike on a 50 year old, cracked, garage floor make me think that I may want to upgrade the casters a bit.
    The other thing I'd point out is that I could BARELY get the bike mounted, I needed a hand from my son. The issue appears to be that the distance from the floor to the Swing Arm connection points seems to be right at the minimum height for the mounting brackets. I think placing one of the wheels on a 2x4 will make it a lot easier to mount the bike.
    The bike seems very stable on the mount in any position so I think I'm going to get a lot of good use from this item.
    Fire away,
    Ski
    Mansfield,MA
    Nice to have the follow up
    Mod Squad
    2009 F800GS 1994 TW200
    Jul 2016
    Milwaukee
    Quote Originally Posted by bogthebasher View Post
    The statement on the ABBA website is:
    "If we manufacture a fitting kit for your bike it will safely lift the bikes weight, you can find this out by using the drop down menus to select your model. The Sky Lift incorporates a 3-Ton hydraulic pump. The lift itself can safely lift a 450kg motorcycle."
    That translates to supporting a bike weight of ~1,000 lbs.
    Ski
    Mar 2015
    King, NC
    Quote Originally Posted by skibumwi View Post
    i
    Hey Ski, I'm interested! Please detail the few issues.
    Thanks!
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    Same here...
    MOA # 108516
    Current ride 2017 R1200RT White
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA
    Jul 2016
    Milwaukee
    Quote Originally Posted by jeffshoaf View Post
    Thanks!
    I've had the lift for quite a few months and the issues are pretty minor, I still highly recommend it:
    1) Because the swing arm pivot is so close to the ground on the '16 RT the lift arms don't quite line up with it , the arms are about 1/2 inch too long. I get around this by parking my bike with the back wheel on a piece of 2x6 wood, and then putting the bike in gear to keep it from rolling off while I'm attaching the bike. By raising the rear of the bike this small amount (1.5") the mounts line up on the swing arm pivot easily.
    2) I'd like to see some larger diameter caster wheels used. The stand rolls around great on smooth concrete but not so good on a 40 year old garage floor with cracks.
    3) This one's really minor and more related to my forgetfulness. In order to use the lift in any other position than stoppie there is a plastic drum that fits into the hub of the rear wheel. You then attached straps between the hub and various points of the lift to achieve either wheelie, or horizontal positions. The problem is that I keep forgetting to remove the hub before driving away, luckily I've found the hub laying in the street about 50 feet down the road so have not lost it. I've attached a piece of rope to the hub and tied it to the lift too keep this from happening.
    Ski
