Results 1 to 4 of 4
Thread: Can someone explain how to remove R100GS left fairing panel?
    Registered User ohiorider's Avatar
    Apr 2005
    Hudson, Ohio
    Has anyone on the forum removed the left fairing section on their 1991 + R100GS? It appears from a physical inspection that it can possibly be removed without removing the instruments and their panel. I'm hoping it is no more involved than removing the windshield, left turn signal, and a couple of bolts that attach the left side to the roo bar and to the headlight surround. Any advice about removing this panel would be appreciated. I believe with the left fairing side removed, I can repair the slightly damaged headlamp socket where the wire bulb retainer is attached.
    Bob (Ohiorider)
    MOA 56434
    Fenwick, Ontario Canada
    Yes it can be done.
    Remove windshield and the mounting lugs.
    Remove signal light & stalk
    Remove fairing fasteners
    Be careful not to scratch paintwork.
    Good luck!
    Ambassador Emeritus BMW MOA Ontario Canada
    Niagara Riders
    Knights of the Roundel #333
    1977 R100RS, (Retired) 1993 R100GS
    Apr 2005
    Hudson, Ohio
    Quote Originally Posted by Darryl Cainey View Post
    Yes it can be done.
    Good luck!
    Thank you, Darryl. Hopefully, getting into the headlight will allow me to do some repair work. Looking at your signature, I see you own one of these nice old machines, too.
    Bob (Ohiorider)
    MOA 56434
    Here's my old gal! I'm the first owner ..... bought her at Andy Pelc BMW, Canton, Michigan, in March of 1991. Today, the odometer shows slightly more than 150,000 miles. Top end has been refreshed with Black Diamond valves, new valve guides and springs, and BMW rings. Still on original pistons. So far, 22,000 miles on top end overhaul.
    This pic was taken in March of 2016. GS was 25 years old at the time.
    Nice looking bike!
    Mine has 51,000 miles 37,000 by me since I bought it 3 years ago. Have it all apart doing the transmission circlip thing.
    Replaced a broken spoke in the rear wheel, R&R shock bushings yesterday only to find the lower shock eye cracked right through.
    Going to a aircraft certified welder today to get it fixed.
    Niagara Riders
