Results 16 to 30 of 34
Thread: Flagpole attachment
  1. #16
    Jul 2016
    Southeastern VA
    And the Ilium bars look easy to remove if he does not want them mounted all the time.
    Picture copied from Jeff Dean's site.
    Unfortunately the Illium bar is a 1" diameter, and the readily available flag pole attachments are for 1/2". Maybe a marine parts place would have something that would work the same way.
  2. #17
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by pkpilot View Post
    Are you saying you can only attach to something with a 1/2" dia?
    Lee
    2016 R1200RS
    MOA # 30878
  3. #18
    Jul 2016
    Southeastern VA
    No. I looked at the brackets at J&P. They only accommodate 1/2" tubing like you see on a rear luggage rack. I really liked the Illium idea. I was considering adding those to my bike, so it would have been an elegant solution. When I get out of the hospital I will check out some marine supply places. They might have clamps that will work.
  4. #19
    Mansfield,MA
    A quick look at "adjustable marine flag mounts" (search) will yield some good result.
    It's a common mount also used on buildings. The marine version is usually stainless. A couple of U-Bolts and you would most likely good to go.
    Mod Squad
    2009 F800GS 1994 TW200
  5. #20
    May 2003
    SW Iowa
    I see what you mean.
    What size flag do you plan to fly?
    Lee
    2016 R1200RS
    MOA # 30878
  6. #21
    OK
    A crash bar, a tube, and some hose clamps and you are golden. Please, son't over think this. Just make it work.
  7. #22
    Jul 2016
    Southeastern VA
    I have not gotten that far. First task was to find a way to attach a flag pole without doing any damage to the bike. Flag size comes next, although it will not be that big. The escorts can easily have speeds above 40MPH, and that is a huge load with a larger flag. The "kits" I have seen online have fairly small flags, which is OK for me.
  8. #23
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    Maybe this?
    There are others out there. You just need to enter the Harley universe.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
  9. #24
    Jul 2016
    Southeastern VA
    Maybe this?
    I have seen that item when I entered the HD universe via J&P Motorcycles. They had several items, including the one you highlighted. The problem is that the Illium rear guard is 1" diameter, and they only have 1/2".
    What I am thinking might work best is a piece of wood shaped to fit in the holes in the rear rack. That would have a hole to hold the base. Then I will need to create braces to hold the upper portion because of the wind loading.
  10. #25
    Jul 2007
    Oh, somehow I thought you neede 1/2 inch. Saw one that is 3/4 inch, but nothing larger.
    Kevin Huddy
  11. #26
    May 2003
    SW Iowa
    Could you use U clamps to attach a 1/2" pipe under your rear rack, then attach the J&P flag holder to the pipe?
    Lee
    2016 R1200RS
    MOA # 30878
  12. #27
    Jul 2016
    Southeastern VA
    That is possible. I found a mount at West Marine that might work nicely with a piece of wood shaped to fit the openings in the rear rack. Of course some techno wizard could probably 3D print that
    https://www.westmarine.com/buy/taylo...07_214_001_503
  13. #28
    Aug 2013
    Bedford, Nova Scotia
    Plenty of options in the marine world.
    If you're looking at West Marine there are a few that should work:
    https://www.westmarine.com/buy/taylo...97?recordNum=7
    https://www.westmarine.com/buy/west-...04?recordNum=2
    Regards, Alan - President BMWONS - MOA Charter Club #097, BMWMOA/BMWRA/BMWONS/Airheads
    Current: '14 R1200RT / '06 Ducati ST3s / '91 R100GS / '86 R80RT / '75 R90S / '73 850 & '70 750 Commando Prev: '04 R1150RT / '81 Honda GL1100 / '77 Suzuki GS750 / '73 Norton 850 Commando
  14. #29
    Registered User gregcrna's Avatar
    Jun 2012
    Grand Rapids, MI
    I am looking for some wisdom/experience from the group on attaching a flagpole to my 2015 RT for Patriot Guard events/escorts. Any good guidance on how to do that?
    Thanks in advance!
    Gorilla Tape?
  15. #30
    Jun 2012
    Grand Rapids, MI
    Quote Originally Posted by gregcrna View Post
    Gorilla Tape?
    Oh thought you mean't for a Harley.
