Results 1 to 12 of 12
Thread: Sun damaged LCD screen
    Cool Sun damaged LCD screen
    Does anyone know of a facility that will repair or replace the sun-damaged screen on the computer readout on my 2005 K1200 LT, or where I could send for the part. According to Max's microfiche, BMW will only replace the entire instrument cluster for a 'measly' $1700. (Bandits)
    If anyone has had this problem in the past, I would like to know how it has been resolved without breaking the bank.
    Thanks, Tony
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Welcome to the forum Tony.
    I wonder if one of those kits for cleaning up hazy plastic headlights would work?
    Can one of the mods move this thread to the Flying Brick section.
    Lee
    2016 R1200RS
    MOA # 30878
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    I used one of those kits from Turtle Wax on a couple of windscreens with extremely good results. If it's just yellowed or fogged, should work just as good on instrument lenses.
    If it's cracked or crazed, obviously the lense would need replacing or the entire instrument replaced with a good one off ebay or from one of the recyclers that advertise in the Owners News.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Dum vivimus vivamus ted's Avatar
    I use the McGuiars 3-step plastic clean and polish on my instrument dial plastic - removes haze and makes them look like new. Might skip the first step for removing fine scratches as that might be a little aggressive for LCD.
    Ted
    "A good stick is a good reason"
    1994 K75RT
    Moto Pages
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Sorry, I think I overlooked that it was an LCD screen. They don't usually haze or yellow. They usually get that dreaded blob under the surface. I don't think that can be fixed. I think it has to be replaced at some level.
    But, if it IS just the surface, plastic or headlight cleaners are worth a try.
    Mine, Hers, Spare
    May 2003
    SW Iowa
    Tony, is the part of the screen you need repaired the center square area?
    Lee
    2016 R1200RS
    MOA # 30878
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    From Max BMW (a dealership in CT): http://www.ebay.com/itm/Bmw-K1200Lt-...tWqSkj&vxp=mtr
    It won't last long at that price!
    If it's just the cover: http://www.ebay.com/itm/Velocimetro-...tXtCEK&vxp=mtr
    Make sure it fits your year.
    Mine, Hers, Spare
    Yes, its the computer screen itself not the plastic instrument cluster cover. The pixels are damaged.
    Kein Nasebohrer RBEmerson's Avatar
    Apr 2007
    SE PA
    Order the part. Once the screen itself goes, there's no way to revive it.
    Some people are wise. Some people are otherwise.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Quote Originally Posted by 150125 View Post
    Buy the used cluster from Max that I showed you and put your cover on it. You'll not get any cheaper than that $99.
    Mine, Hers, Spare
    Talked to Max in CT. to make sure it was compatible. Ordered the part through ebay. Thanks for the tip.
    May 2003
    SW Iowa
    Good to here you're fixed up.
    Thanks for the update.
    Lee
    2016 R1200RS
    MOA # 30878
