Results 1 to 12 of 12
Thread: 2017 XR rubber handlebar mount kitto fit 2016 XR
    Has anyone heard anything about BMW offering the rubber handlebar mount on the 2017 S1200 XR in a kit to retro fit to a 2016 S1200 XR?
    Yakima, WA
    Quote Originally Posted by 146023 View Post
    You'd probably get a better response in the correct forum.
    Randy
    CURRENT: R1200RS, R75/7
    PAST BMWs: 2013 R1200RT, 2002 R1150RT, 1982 R100RS, 1993 K1100RS, 1993 K1100LT, 1989 R100RT, 1978 R80/7
    Quote Originally Posted by CRUZER View Post
    You would probably get a better response from a dealer who actually knows.
    Debbie's Servant Lee's Avatar
    SW Iowa
    Is a rubber handlebar mount how BMW fixed the bar vibration problem?
    Lee
    2016 R1200RS
    MOA # 30878
    Liaison 20774's Avatar
    I'm not familiar with the S1200 XR model. Other posts by this member seem to all be directed at a Wethead model.
    CENTEX USA
    That would be a S 1000 XR, considered a Hothead here
    I will move this over there soon
    Had read in Bench Racing maybe about the upgraded damper/handlebar issue coming soon, nothing on a retrofit kit though
    If a kit was available anytime soon, a dealer would be a good source for that info as mentioned. Just as other upgrades and spare parts often takes some time to get in the available parts chain.
    Steve Henson
    The retrofit is available for 2015 and 2016 S1000XR. Part 11 on the triple handlebar/clamp/fork fiche of the manual diagram (softer rubber insert). You need to specify that your handlebars vibrate between 4000 and 5000 RPM to the dealer for it to be replaced. The part cost $3 and would take 30 minutes to do it yourself, if the dealer wants to charge you. Some dealers are doing it for free I heard in another forum. When mine goes in for service I would ask for the retrofit, as per comments it does improve the vibes.f If you have a 2015 or early 2016 mfg. bike you main also have to change part 14 (from a hard plastic to a softer rubber). Below link to parts diagram.
    http://parts.motorcyclesofmiami.com/...428554473.html
    Registered User andrewbrandon19's Avatar
    Sep 2015
    Newport News, VA
    What about the singe R? The mirrors are useless on the highway and the rubber mount for 2017 was supposed to fix it.
    2015 BMW S1000R - The DD
    2014 Toyota Taco - The "guess its raining today"
    2013 Harley Davidson 883 Sportster - SOLD
    2006 Pontiac GTO - SOLD
    I ordered the top and bottom bar rubbers - the specific parts for 17 are just the two bottom donuts but my bike has a late '15 build date and there is an update to the tops from '16. I just got shipping notice yesterday from Max in NH so I should have them Monday or Tuesday.
    Posts on the UK XR forum indicate they are softer and do make a difference. My bike is not especially buzzy like some people have complained about - I don't even have aftermarket bar end weights installed. But, for $20 I figured I'd get the rubbers while I was ordering the parts to add the GS lock kit to my GPS prep and glom the shipping.
    I'll report back once I have had them in for a while.
    My dealer is installing the new rubber mounts at no charge to the customer. I had my XR fitted with the new mounts and the handlebar vibrations are gone! I can actually make out the images in my mirrors now. BMW is not doing this as a recall; the customer has to make a complaint to the dealer about the vibrations they are experiencing before the dealer can do the retrofit.
    I'm buying a '16 demo bike (115 mi) this weekend and I asked that they install these parts prior to sale. I don't think they are going to get them in time so I may just get the parts from them when they come in and do it myself but they were going to do it for free.
    BTW, I'm hearing no '17's in the states this year - mainly because of the glut of '16's leftover.
    I got and installed the parts yesterday. I guess my bike is/was not as buzzy as some to start with since my mirrors were mostly clear and prolonged freeway isn't bothersome. I don't have bigger end weights or anything.
    The install is quick and painless with a T-45, T-50, and a 15mm wrench. The new bushings are much softer than the originals but... for me there isn't any difference before/after that I can tell. It feels exactly the same. Which is fine... I only bought them because I was already ordering stuff and another couple bucks to try it out wasn't a big deal.
    Maybe if you have a stong vibe these will help but I didn't and I still don't.
