Results 1 to 11 of 11
Thread: Jump Start Battery pack for C650GT Scooter
    Can Anyone Suggest a Jump start battery pack that has the accessory wire harness like a battery tender to jump start a scooter?
    I have to park the scooter in a storage unit with no electric for a battery tender for a extended period of time.
    In the event of a dead battery I would like to be able to easily start it.
    I don't want to have to dismantle the battery cover panel and remove the battery and find a place to recharge it.
    Registered User jek_ict's Avatar
    Aug 2015
    Wichita, KS
    Does the scoot use a 12V battery like bikes? I've successfully jumped my bike with a borrowed Red Fuel Portable Jump Starter available from Walmart for around $50. However, this model doesn't have the SAE adapter used with most chargers and doesn't appear to have one available as an optional accessory.
    I've heard good things about Weego, but I've never used one and it is twice the price of the Red Fuel.
    ~Jason
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by apwilson54 View Post
    When using a jump start battery pack it would be best to connect it directly to the scooter battery terminals.
    All the jump packs I have seen have alligator clips for jump starting.
    Lee
    2016 R1200RS
    MOA # 30878
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    I have a couple of Anti-Gravity Micro Start units. Bought one and got another as a gift. I've started a few motorcycles and my pick-up a dozen or more times as I sorted out a battery issue. They work well. The Anti-Gravity are pretty pricey, but when I bought mine they were one of the few available. I've seen other brands selling for half the price at Walmart and Costco, but I do not know how they perform.
    As Lee said, best to go directly to the battery unless you have a harness that has wire of a heavy enough gauge to handle the jump start load. On my FJR I wired in a remote battery terminal so I could jump or be jumped without digging into the fairing. The remote terminal has a wire that is the same as the OEM battery leads.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Mansfield,MA
    Welcome to the forum!
    It's good to see some activity in the scooter forum section.
    I don't know the setup of your storage facility but a solar power trickle charger may work for you. They are not real powerful and therefore have wires that may be small enough to see the light of day.
    Let us know how you make out.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Sep 2006
    CENTEX USA
    Have not looked at a C series up close, but do they have the positive post remote connector handy like the F series do?
    Steve Henson
    May 2003
    SW Iowa
    Doesn't sound like it reading these instructions.
    https://www.manualslib.com/manual/92...t.html?page=99
    WebBikeWorld has a few pictures.
    http://www.webbikeworld.com/bmw-c-65...50-gt-battery/
    Lee
    2016 R1200RS
    MOA # 30878
    Batery jumpers.
    Harbour Freight has a decent one and very compact also. Jumper cables attached etc.
    Mo Shaffer
    Maggie valley NC,
    St. George, BM
    Aug 2013
    Bedford, Nova Scotia
    Can Anyone Suggest a Jump start battery pack that has the accessory wire harness like a battery tender to jump start a scooter?...
    Do not try to jump start your vehicle using "accessory wire harness like a battery tender". A battery pack suitable for jump starting will fry those small gauge (typically 18 AWG) wires which at best will require replacement and at worst you might fry much more which can be quite costly. You need a 12 AWG cable at the minimum, preferably 10 AWG.
    What I use on my RTW is the Micro-Start XP-1 lithium battery pack and I have their "Starting Harness" wired to the battery.
    There may be others available, but this is what I know and use.
    Having said that, I would not recommend storing the scooter with the battery connected and no charger for anything over 1-2 months. It puts a significant strain on most types of batteries and noticeably reduces their lifespan. It would be far better to install a battery cut-off switch if you have the room somewhere, preferably marine grade like this one- https://www.waveinn.com/nautical-fis...-off/1289515/p
    Regards, Alan - President BMWONS - MOA Charter Club #097, BMWMOA/BMWRA/BMWONS/Airheads
    Current: '14 R1200RT / '06 Ducati ST3s / '91 R100GS / '86 R80RT / '75 R90S / '73 850 & '70 750 Commando Prev: '04 R1150RT / '81 Honda GL1100 / '77 Suzuki GS750 / '73 Norton 850 Commando
    Jul 2016
    Sugar Grove, IL
    I keep a Anti-Gravity Micro Start XP-3 under the seat of mine. Never had to use it for bike, but I have started a couple cars with it. Only the 4 torx screws to remove if need to jump so haven't seen need to install external wires to jump. Can be used as backup to charge phones and other devices if needed so handy little battery.
    I keep a XP-1 in my SUV as well. Able to start my wife's van with 3/4 charge no problem and much smaller than the larger commercial jumper packs.
    As stated previously, best to not let battery run down if can be avoided as it shortens the life. Keep on Smart Battery charger like a Battery Tender if not going to be used for a longer period of time.
    2014 BMW C650T
    MOA # 208387
    rsbeemer 22600's Avatar
    Jan 2011
    New Braunfels,Texas/Taichung, Taiwan
    Just my 2bits
    I know you said you don't want to remove battery but from experience I can tell you that your battery will last a lot longer if you take it out and put it on battery tender. Leaving it sitting there for months is just asking for trouble. I'm away from my rs sometimes a year or more. In the beginning I used to just unhook the cables and then try and revive it once I returned but found out that just sitting there uncharged somehow deteriorated the cells. I now have it on a tender and have no problems; it's ready to go once I put new gas and oil in and always starts up. I don't know about he carbs on your scooter but run them dry and put keeper of some sort in your fuel. Good luck.
    1978 R100rs MOA#22600 125cc Kymco , 180cc Kymco Racing King
    The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails.
