Results 1 to 15 of 19
Thread: 07 RT1200 front brake bleed just sucks air in reservoir
    installed rebuilt abs module, rear brake fine but vacuum pump just keeps sucking air in front reservoir instead of fluid,I tried left and rt .there is no bleed screws on the module itself so I am bleeding from the calipers, Bruce
    Quote Originally Posted by 174859 View Post
    Do you have a GS-911?
    Brian Hinton
    2007 R1200R
    2007 K1200GT
    2016 R1200GS
    2007 rt1200
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    2007 rt1200
    Welcome to the forums. The GS-911 Brian asked about is a diagnostic tool that can be used to read and reset fault codes and activate some maintenance functions. On some models it can be used to reset the service reminder, but I don't think your bike has a reminder. Brian may be thinking that the GS-911 could be used to activate the ABS pump to facilitate getting fluid into the system. I don't recall that function being possible on the 07 RT but I may be wrong. There are some very knowledgeable folks on the hex head forum and one will assuredly be along to help you.
    Just for your information, there is an extensive DIY subforum available for the hex heads. It provides excellent how-to advice for all the routine maintenance procedures. The DIY library is at the top of the page when you enter the hex head forum. When you enter the library you will not see any threads. You will see a option drop down box that says "Last Year". Change that to "Beginning" and then click the "Show Threads" box on the right side of the page.
    Good Luck!
    Kevin Huddy
    Spring Lake NJ, USA
    Good Luck!
    The GS-911 can do the bleed ABS modulator on the 2007 R1200R (Hi Brian!) - so I would have to believe it could do it on an RT - same system, same brakes.
    tried to bleed the master cylinder but just keep getting air bubbles from the fill hole for the piston cup, could the cup be swelled and sticking? or am I overlooking a different problem
    So, as the guys above mentioned (hey Don!), the GS-911 will bleed the ABS pump, but now you're on to the master cylinder with bubbles. I guess I will step back and ask where you got the ABS rebuilt? As far as I know, and I could be wrong here, but most rebuilds are ready for installation I thought (someone jump in here if I'm incorrect). But then I ask the question again, do you have a GS-911 or know somebody with one? If the rebuilt abs was in fact ready for install then you just need to bleed the brake lines per the wonderful instructions in the tech sub forums. (Thanks again Don!)
    Brian Hinton
    2007 R1200R
    2007 K1200GT
    2016 R1200GS
    May 2016
    Northfield, Ohio
    If you do not have the GS-911 another way to get the ABS pump to run is put the bike on the center stand and turn the back wheel while you apply the brakes. The bike will sense that the back wheel is turning and the front is not and activate the ABS system. Do this a few times while you are bleeding the brakes. This will get the air out of the ABS pump.
    Roger L
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Have you tried to bleed the circuit directly using pressure instead of vacuum? Fill the master cylinder reservoir, and push fluid through the system using the hand brake lever, alternately opening and closing the bleeders on the caliper. If there's a stuck bubble in the middle of the circuit, this would have a better chance of dislodging it.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    Yes it does. The function is available for my 07 RT (GS-911 WI-FI)
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
    kellenbenz kellenbenz's Avatar
    Dec 2012
    Tyler, Texas
    I had my ABS module on my 2008 RT rebuilt by Module Masters and had a bit of a problem getting the fron brake not to be spongy after the reinstall. I searched the problem and someone mentioned to put the bike on the center stand and bungie the brake handle to the pressed position and leave it overnight. I woke up to a perfectly hard front brake the next morning. I didn't believe it either but give it a try....nothing to lose.
    Ron
    IBA 45658 MOA167437
    728,482 miles on touring motorcycles
    Total BMW miles 490,099
    Spring Lake NJ, USA
    Quote Originally Posted by kellenbenz View Post
    Ron
    That was probably me. It was by the advice long ago given me by Joe Katz (RIP) Master BMW Mechanic and owner of BMW-Orlando. As he said to me "Gravity sucks.." The idea being to let the system sit pressurized overnight and when you release the brake lever in the morning the bubble that finally travelled up the brake lines to the master cylinder burped out the pressure relief hold in the master cylinder. I found it hard to believe until I tried it. I've also used it on cars - with similar success. Go figure!
    Nov 2007
    The pressure makes the big bubble tiny so it can move up the hose easily
    Rod
    Spring Lake NJ, USA
    Quote Originally Posted by ragtoplvr View Post
    Rod
    Excellent! Now we know why it works.
