Results 1 to 8 of 8
Thread: K75 Fork gaiters?
    Registered User TOM1911's Avatar
    Mar 2007
    Middleburg Fl.
    K75 Fork gaiters?
    I've been trying to find a set of gaiters for the K75 that has finally worn out the springs, seals and dust boots that were original to the bike. Ihave seen in other posts that Rancho Suspension makes a nice set of gaiters but i have not been able to find a part number or a supplier for these items. I,m rebuilding the forks and I live in a sandy and dusty environment and gaiters sound like they would help extend the life of the fork seals. Any help would be greatly appreciated.
    '91 K75 Marrakesch Red
    Tom,
    Google turns up http://www.gorancho.com/home.php
    I don't have the specific model ##.. but http://www.gorancho.com/products/acc...ccessories.php lists some in lots of colors..
    These weren't made for "forks" - the ones that were on my K75S were shock absorber boots - probably the black ones shown on that page.
    Tom,
    I agree with Don...those Rancho boots fit the K like a glove and are cheap!
    Hit their website and find their local supplier...
    Edde
    93 K75s
    www.motoedde.com
    Blocking the slow lane
    Edwardsville, IL
    I use the classic /5 fork boot on my K75. The ladies dig it.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    Mar 2007
    Middleburg Fl.
    Thanks Don.. Just ordered a set of Rancho RS1952 thru Summit Racing. Should do the job admirably
    I wanted the accordion fork boots on my 92 K75S. I went to Re-Psycle BMW and obtained the boots. A set of K75S fork lowers and fork tubes were used to make certain that the boots would fit. The part number for the fork boots (which fit perfectly) is 31-42-2-311-077. I used some old clamps of the appropriate size to secure the boots to the forks.
    I had some issues with extracting the fork tubes from the triple clamps. I used a good bit of heat from a propane torch on the lower and upper clamp (after removing pinch bolts!). The fork tubes slid out after heating.
    Although I cleaned the inner surface of the upper and lower clamps with scotchbrite, it was necessary to use heat to allow the fork tubes to be inserted.
    13278
    Near Lynchburg, VA
    Check out Amazon for the RS1952's. $5 or less each, I think. I've done 2 K75's and will definitely do another when the forks come off for some other reason than to put fork covers on. One of the cheapest additions to your bike you will ever buy.
    I did trim (with scissors) the lower inside of each boot so that the tie wrap and boot fit properly.
    Charlie
    Quote Originally Posted by 72r60/7 View Post
    Check out Amazon for the RS1952's. $5 or less each...
    Sigh! I did see that the RS1952 boots would work AFTER I'd obtained and installed the BMW fork boots. I did purchase a couple of the RS1952 boots from Summit Racing for my other K75S (or airhead GS as this was the basis for the BMW boots from Re-Psycle).
    It might be worthwhile to sticky the link to Summit Racing and note that the RS1952 boots are a much less expensive alternative to the BMW boots for the K75S.
    https://www.summitracing.com/parts/ran-rs1952
