THOMASPIN
Airhead
I just had the carbs professionally overhauled after a long lay up and the machine ran well. I synched the carbs using CarbTune and the 4,000rpm sweet spot was there. However, gas mileage was very poor at 22mpg. I am used to getting twice that. The bike started easily and ran well at all revs/gears.
So first I checked the valve clearances and they were correct.
I reattached the alternator cover (I use the alternator bolt and an Allen wrench to turn the motor with the spark plugs removed) and no ignition. Starter works fine. Checking, I noted that I had managed to pinch the cable from the points to the condenser; the rubber sheath had slipped off its mounting while I was securing the cover allowing the yellow sheathed points cable to be pinched and completely severed when the alternator cover bolts were tightened. The battery was disconnected at the time I pinched and cut this wire so no short should have resulted. The cut inner wire remained partially sheathed by the yellow jacket and, I assume, insulated from the chassis.
Diode board is a Thunderchild.
I then replaced the points with a new BMW OEM set, and replaced the condenser with a new one just because I had it handy.
Then I checked the points gap - also correct.
I can get the bike to start - the starter works fine - but regardless of how I set the timing throughout the available range it will stall once I open the throttle, generally after a backfire or two. What can have caused this when all I did was check the valve clearances and replaced the points and condenser?
Any help would be appreciated.
Thomas
1975 R90/6 - second owner since 1990.
Thomas
