Results 1 to 7 of 7
Thread: Help, please
    Apr 2016
    Central Suffolk, Long Island
    FIXED. Help, please
    Today, I go to post a reply msg and my screen looks like the attached. Can't seem to figure out why or how to get it back. Any ideas?
    Liaison 20774's Avatar
    Well, that's pretty weird! Can't say as I've seen that before. I'm assuming you've been able to come to the forum and post before with no problems. Since you posted this message, have things corrected themselves?
    I'd suggest two things. One would be to go to the lower left hand corner of the main forum screen and try a different skin. Second, I'd suggest logging off the forum, then logging back again. Hopefully one of those two will remedy the situation. Let us know.
    Apr 2016
    Thumbs up Thank you
    And SKINS it is.
    I had tried all the other and then some before asking for help.
    All's good again in MOA world.
    Thank you.
    That's great!!! Can you remember which skin you were using that caused the problem? I'd like to track that down.
    Found it. It was the skin labeled "R1150RS". I'll have to track down what's wrong with it...at a minimum, I can turn it off so it can't be used.
    Apr 2016
    Correct.
    I think it's fixed. Let me know!!
    Update...found several others with the same problem. I used the same fix for all.
