Page 9 of 19 FirstFirst ... 7 8 9 10 11 ... LastLast
Results 121 to 135 of 275
Thread: The New BMW G 310 GS Thread~
  1. #121
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    I have a Jesse topcase with a built in 3.5 gallon fuel cell. Maybe I'll mount that bad boy. Around 450 mile range then. That ought to be enough.
    That will do it!
    MOA # 108516
    Current ride 2018 R1200 GSA Triple Black
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA, ‘17 R1200RT
  2. #122
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Apr 2008
    Calgary AB
    Quote Originally Posted by RIDERR1150GSADV View Post
    That will do it!
    +1!
    Ken Dittrick
    2008 R1200RT (Biarritz Blau)
    Excuses are the rocks upon which our dreams are crushed - Tim Fargo
  3. #123
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    Wouldn’t help me much. I have a 150 mile bladder.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
  4. #124
    F650624 f650624's Avatar
    Feb 2008
    Fort Worth, TX; Eagle River, AK
    Hello
    It is winter here, it will only get to the mid 80s today. I just got back from a 150 mile ride for brunch. So when you meet me on the road will you still wave?
  5. #125
    Is that a long ride?
    Gail Thorne
    2017 F700GS
  6. #126
    Feb 2008
    No, about average for coffee or lunch. My longest one-way was just under 7000 miles when I rode my F650GS back to Alaska. My youngest son rode with. It was the best trip ever.
  7. #127
    sMiling Voni's Avatar
    Voni
    sMiling
    BMW MOA Ambassador Emeritus / FOM / Roving Forum Moderator/
    Selected Friends of Wile E Coyote/ A Million 100 thousand BMW sMiles
  8. #128
    May 2004
    NH
    Voni,
    Good luck with your new motorcycle.
    Thomas Sells
    00 K1200RS, 03 F650GS & a 06 Ural Patrol
  9. #129
    Mansfield,MA
    I hope they get this bike rolling, delivered, sorted and supported- soon.
    It looks like Honda will be nipping at the market soon with the XRE 300-
    Looks like-
    Honda XRE 300 patent image leaked in India; Will compete against KTM 390 Adventure, Royal Enfield Himalayan & BMW G 310 GS
    Mod Squad
    2009 F800GS 1994 TW200
  10. #130
    A Review from Malaysia:
    RM29,900 is 7333.87 US Dollars
    https://paultan.org/2017/12/07/revie...sizes-rm29900/
  11. #131
    Mansfield,MA
    Seems to be getting close(r)- From a BMW message today-
    The BMW G 310 GS. Everyday adventures.
    Be spontaneous, break the routine, and make everyday life into an adventure. Whether it’s your daily commute to work in the city, a trip through the countryside, or through forest trails and rough roads, the G 310 GS promises pure riding joy for everyone. It carries you through the urban jungle and allows you to take on any challenge with precision, confidently and carefree. With this machine, adventures don’t have to be big to be unforgettable. What matters is that you experience them every day.
    Typical GS.
    This bike is unmistakably a GS – robust and diverse. With its classic adventure design, the G 310 GS embodies the GS Spirit. The renowned GS ergonomics bring a commanding riding position on any surface.
    Light and confident.
    The G 310 GS makes for relaxed riding. It’s arranged in a balanced way, making it easily reachable for riders big and small. The bike is agile and steers easily and precisely through the city or along forgotten streets to the next adventure.
    Dynamic mixture.
    The bike’s single-cylinder engine is striking. Its unconventional engine arrangement lowers the vehicle’s center of gravity, and offers endless riding comfort and control. Inside this machine, you will find the unmatched quality and expertise that can only be found on a BMW Motorrad bike.
    Extremely well equipped.
    Dual-channel ABS is included as standard equipment, and naturally there's a range of special accessories so you can configure your ideal ride.
    Engine
    Type Liquid-cooled, single-cylinder 4-stroke engine, four valves, two overhead camshafts and finger followers, wet sump lubrication
    Bore x stroke 80 mm x 62.1 mm
    Capacity 313 ccm
    Rated output 34 hp (25 kW) at 9,500 rpm
    Max. torque 21 lb-ft (28 Nm) at 7,500 rpm
    Compression ratio 10.6:1
    Mixture control / engine management Electronic fuel injection
    Emission control Closed-loop 3-way catalytic converter, emission standard EU-4
    Performance / fuel consumption
    Maximum speed 89 mph
    Fuel consumption 71 mpg (WMTC)
    Fuel type Premium Unleaded
    Electrical system
    Alternator Three-phase 308 W generator
    Battery 12 V / 8 Ah, Maintenance free
    Power transmission
    Clutch Multi-plate wet clutch, mechanically operated
    Gearbox Constant-mesh 6-speed gearbox
    Drive Chain drive
    Chassis / brakes
    Frame Tubular steel frame with bolted rear frame
    Front wheel location / suspension Upside down fork , Ø 41 mm
    Rear wheel location / suspension Solid die-cast aluminum swingarm, directly hinged monoshock, adjustable preload
    Suspension travel front / rear 7.1” / 7.1” (180 mm / 180 mm)
    Wheelbase 55.9” (1,420 mm)
    Castor 3.9” (98 mm)
    Steering head angle 63.3°
    Wheels Cast aluminum wheels
    Rim, front 2.50 x 19"
    Rim, rear 4.0 x 17"
    Tires, front 110/80 R 19
    Tires, rear 150/70 R 17
    Brake, front Single disc, diameter 300 mm, 4-piston fixed caliper, radially bolted
    Brake, rear Single disc, diameter 240 mm, single-piston floating caliper
    ABS BMW Motorrad ABS
    Dimensions / weights
    Length 81.8” (2,075 mm)
    Width (incl. mirrors) 34.7” (880 mm)
    Height (excl. mirrors) 48.5” (1,230 mm)
    Seat height, unladen weight Standard Seat: 32.9", High Seat: 33.5", Low Seat: 32.3"
    Inner leg curve, unladen weight Standard Seat: 73.7", High Seat: 74.9", Low Seat: 72.5"
    Unladen weight, road ready, fully fueled 1) 374 lbs (169.5 kg)
    Permitted total weight 761 lbs (345 kg)
    Payload (with standard equipment) 387 lbs (175.5 kg)
    Usable tank volume 2.9 gal (11 l)
    Reserve Approx. 0.3 gal (1 l)
    Technical data relate to the unladen weight (DIN)
    1) According to guideline 93/93/EWG with all fluids, fueled with at least 90% of usable tank volume
    I'd like to take one for a test drive.
    http://www.bmwmotorcycles.com/us/en/...html&notrack=1
    Mod Squad
  12. #132
    Jan 2005
    Grayling, MI
    Looks like-
    Looks like the fork tube protectors are in the wrong place.
    Wayne Koppa
    Grayling, MI
    #71449
  13. #133
    Mansfield,MA
    Quote Originally Posted by wkoppa View Post
    Wayne Koppa
    Grayling, MI
    #71449
    It seems like it's been a long time since Honda made an error.
    Mod Squad
  14. #134
  15. #135
    Rally Rat 1074's Avatar
    Sep 2004
    Las Vegas, NV
    Great! So when is BMW going to make a bike designed for less than premium, high octane gasoline?
    Boxerbruce
