Results 1 to 15 of 16
Thread: Coolant change interval for new water boxer
    Does anyone have info/recommendation for changing out the coolant on the new water boxer? I can't find any change interval in the BMW service manual. Time/mileage interval?
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    Service Manager told me NEVER. I said seriously and he said seriously
    I would look at doing it at 3-4 years or so. I already have a gallon from the car dealer.
    I know it is high quality and is supposed to be lifetime, but I will do mine on a service when it suits me. I do not believe anything is lifetime.
    However that said we go back to our cars and never changing our anti freeze or brake fluid and we all live to drive another day
    Lee
    2017.5 R 1200 GSW
    Quote Originally Posted by LFarling View Post
    Yes, and a radiator for my car cost me $80 with free shipping and one for my K75 is $670. So it pays to be a bit fussier with our bikes than our cars.
    Smile Coolant change interval
    Paul, I agree with your assessment. I live in the Northeast and usually get 15-20K miles per year. Does change interval at 2 year/36K sound reasonable to you?
    Nov 2004
    Arizona, USA
    The OEM Repair Manual for the R1200R LC and the R1200RS LC calls for a coolant change at 18,000 miles.
    I just completed an 18,000 mile service and the coolant change was a no brainer, easy to do with no real surprises.
    Do drain the overflow tank before you open the radiator fill cap. Ask me how I know.
    Deryle Mehrten
    Sierra Vista, AZ USA
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by mehrten View Post
    Deryle Mehrten
    The list the shop printed for me only shows checking the coolant level at 18,000 miles.
    Did you use the vacuum method when you changed the coolant?
    Lee
    2016 R1200RS
    MOA # 30878
    Mansfield,MA
    I haven't changed antifreeze in anything in a very long time. The systems are tight and the fluids are better so I don't worry about it.
    I do however add the Prestone anti-rust and water pump lube-
    http://prestone.com/enmx/node/1428
    And, I think it has helped. I have one engine at 26years, 8000 plus hours and the block's interior looks great. I do check the freeze point from time to time.
    Everybody does it different.
    Mod Squad
    2009 F800GS 1994 TW200
    Quote Originally Posted by 146023 View Post
    Two years would be my preference, even four beats never.
    Sep 2006
    CENTEX USA
    I recall that was the original stance on the EVO final drives...Lifetime fill was the head scratching guideline....and that became a bit different very quickly
    Steve Henson-Mod Team and club tire changer
    The mechanic that maintains my cars and truck checks the coolant's PH, or some chemical indicator. They change it if it goes out of spec. They do this every time I bring it in. So far, they have never had to change it and that's over 100,000+ miles on each. There is a condition that can cause damage to the engine, corrosion no doubt, if the coolant goes bad.
    Larry
    Jul 2008
    Central PA
    What was the factory recommendation it on the old K-bkes? I can't remember. It seemed like a long time.
    Cave contents: 16 R12RS, 13 Toyota Tacoma, 03 Simplicity Legacy, 97 Stihl FS75, Dewalt DW625 & SawStop PCS175
    1) My expectations are never low enough & 2) Incompetence is infinite ........David Brooks
    wanderer
    Jun 2009
    Bridport Vermont
    The modern coolant chemistry resists corrosion and break down much better than in the past. Modern engine and radiator design specifying the best materials also greatly extends the life of coolant. I have to assume BMW does a good job of both!
    One car says 7 years another says 5 years.
    I believe 5v years is totally safe. evan longer is probably safe.
    Now if you have added tap water or some cheap coolant...you have violated the integrity of the system...so a shorter time seems prudent.
    But I know of some you feel better doing its sooner. Just like changing oil at 3 k miles.
    As always if you feel better doing it sooner...change it. It is only $$$
    May 2003
    SW Iowa
    Quote Originally Posted by 36654 View Post
    On the K1200RS Brick it was every two years.
    I thought that was too often but I did it because it was easy and cheap to do.
    Lee
    2016 R1200RS
    MOA # 30878
    Albuquerque, NM
    Quote Originally Posted by bobzeliff View Post
    It's also environmental pollution.
    Kent Christensen
    21482
    Nov 2004
    Arizona, USA
    Lee,
    Our R1200RS had a seep, weep, leak out of the water pump drain hole (that went away at about 5,000 miles).
    Consequently I've kept an eye on the coolant level, adding about 25~50 cc's a couple of times over our first year of ownership.
    Draining and refilling the coolant was an easy job. I had some BMW coolant left over from doing the K-GT and the K-RS, so why not.
    Yes, I use an older Air Lift tool. l added an additional valve to it to make it a bit more user friendly like the later versions are.
    Also, I recycle all my waste fluids, bottles, cans, paper...etcetera, etcetera, etcetera...
    Deryle Mehrten
