Results 1 to 5 of 5
Thread: Test forum?
    Apr 2006
    Nibley, UT USA
    Test forum?
    Trying to sort out the process for creating or embedding links using an iPad. Is there such a thing as a test forum on the site, where one can experiment without annoying the masses?
    Thx,
    DG
    DGerber
    1983 R80ST 1984 R80 G/S-PD 2004 K1200GT w/Hannigan S/C 2010 K1300GT 2018 R1200GS
    Liaison 20774's Avatar
    DG -
    Not specifically. I suppose you could continue to try posting in this thread. If we learn something significant, maybe we keep the thread. If not, then maybe the thread gets deleted at some point.
    Mansfield,MA
    Quote Originally Posted by GTRider View Post
    Thx,
    DG
    Do it right here. Chances are any question you have or "procedure" you use will be of interest to many Members.
    I've found that sometimes a link works a little different with the iPad. I suspect it because the iPad is "seen" as a mobile version.
    If you need help, just ask.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Still Wondering mika's Avatar
    Aug 2004
    Fly Over Land
    Use the preview function allows you to see your post before it goes up. The only thin preview will not show is an embedded video. I use this to check for errors, broken links and other things before posting in BR&TMR thread.
    Apr 2006
    Nibley, UT USA
    Link Test
    Thanks, think I have it figured out now. I just needed a spot to tinker with to make sure I had it right.
    Best,
    DG
    DGerber
