Wondering about the 2016 RT
217don
Member
I test drove one and liked it but did notice that sometimes it shifted smoothly, sometimes I thought I could actually feel the gears engaging and sometimes it made a satisfying agricultural clunk as it engaged. Is this typical? I kept it under 4000 rpms so that may have had an influence. Also I noticed in the most recent MOA magazine that maybe the wheels are prone to failure - anyone else experience this? Any idea how widespread that may be? And lastly there seems to be a weep hole issue. Is this a gremlin plagued model?
Hi 217don - I have a 2015 RT. It was a demonstrator with 1200 miles on it when I got it. I now how 20,100 miles. I just returned to Boston after an 8890-mile romp over to Oregon, down to LA, then back home across the Southwest and South.
It seems to me that the transmission is very solid, provides a "clunk" when going into 1st gear at a stop, and thereafter shifts they way I think it should. I have what BMW calls the "Gear Shift Assistant Pro" which allows some non-clutched shifting simply by moving the shift lever. In practice, I find the upward shifts from 3 to 4, 4 to 5 and 5 to 6 as the best and smoothest. Downshifts (with throttle closed) are very smooth from 6 through 1. The electronics blip the RPMs a bit on each downward movement. Since the bike has a slipper clutch, this seems to moderate engine braking some.
I had not heard about wheel issues. Perhaps I should look. Roads in Massachusetts are pretty awful, so it's something I'll have to watch.
As to the weep hole and some coolant appearing on the side of the engine case (left-front), I had some of that early on between 3K and 7K miles. I think that some water pumps were replaced under warranty in RTs and GSs. The service manager in the Asheville, NC BMW store looked at that when I was down there in April. He advised me to get someone to look at it if I ever found any accumulation under the bike on the ground. I have been through the 12K and 18K services, and the service people said all was fine.
I don't think it's a gremlin-plagued machine, but this would only be anecdotal information from one rider. There are some changes in the works for the 2017 models, so you might look at that. I see that BMW Motorrad has a $1750 incentive on 2016 RTs, so maybe that's a factor.
I hope this is helpful.
John Gamel
2014 RT here. I've had this bike for 1,500 miles ( bought it with 6,200mi) but have been renting them on and off for 3 years. Other than the clunk into first, I've noticed the longer I ride, the better it gets. I'm sure the bike is the same, just the rider learning what this transmission likes. I short shift due to the plentiful amount of tourque between 1-2, 2-3, then clutchless the rest of the way. Quite smooth now. I have a VFR Honda, and by no means is it Honda smooth, but getting better all the time. BIke never had the weep issue but from what I read I wouldn't be too concerned. And like the other responses, I haven't heard anything about wheel problems. All in all, quite happy with the bike.
John Gamel
Thanks, John. Very useful info and I appreciate the reply. My wife and I often tour in New England - Vermont 100 last summer
418 miles I had a weep. 2015 RT loaded. I had a few drops not a river or anything. Called the dealer documented it with pics and continued riding it. Never a drop since. Dealer said to wait and see if it was a issue or the seal needed a bit of time to seat. He said it made no sense to pull the front half of my motor apart to put in the same run of parts that are in the system and very well will probably leak again. He was right.
Wheels not sure of that as never in all the forms have I seen a post on a RT wheel. Other then a pothole deal or something.
Shifting is all over the place on these bikes and I am not sure if it is bike specific or rider specific? I at times snick gears like butter and others it is like shifting a tractor and one wonders if you need to double clutch :)
Been some switch issues in the past but dealers address them very promptly.
Love the bike and mine has been pretty good to me with no major problems.
Thanks. Very useful. Wheel issue was in a letter to the ed in MOA News with, unfortunately, no response from our club leadership.
Perhaps you referring to soft rims that might bend on hard road hazard impact? Some years ago, but I think they are tougher now. Most cast wheel are prone to hard impact.
217Don,
I have a 2016 that I've put 16,000 miles on; FANTASTIC bike! :dance
Pro shifter is great once you learn it. Transmission only "clunks" going into first when stopped.
My bike has an annoying clutch problem that only a very few seem to have; the engagement point jumps (for lack of a better description) out as the bike warms up. I adjusted the clutch so that it engages close to the grip when cold, therefore when it jumps I still have good control with my small hands. Just an inconvenience. Dealer replaced the clutch slave cylinder under a recall, but no change.
Just had the low beam burn out; no other problems.
I ride both single and two up and get ~ 50 mpg.
Had an R1200RT for 7 years and nearly 80k miles. Granted the shifting got smoother with mileage, but like jswisc commented, it's not Honda-smooth (you need a Honda for that!).
Not sure what the 'wheels concern' is all about, other than you have to avoid potholes with cast rims, as they bend/kink more easily than others.
Perhaps it was a reference to the FD at the rear wheel? If so, best of luck, but BMW never did admit to or significantly re-engineer that gremlin. I know of current owners still biting that bullet.
Good luck with the bike and ride often. :thumb
The letter is in the November issue of the MOA News so don't know much more than what the writer said. Seems he bent a wheel as have several other riders. Not a problem I have had in 40+ years of riding, some with cast wheels!
Thanks for the post and info. Am I correct that FD failures are still happening to 2016 bikes? Yikes. Would love to hear from other owners on that issue. Maybe it's a case of the emperor's new clothes.
The FD appears to be reliable for wetheads so far. I've heard of only a couple of failures since the 2013 GS was introduced.
I took delivery of a custom ordered '16 RT on March 18, 2016, just past 16,000 miles, and it's been flawless. It seems to just get better and better at shifting smoothness and vibration dampening. In fact I ordered my RT w/o Shift Assist Pro, and I can shift ultra quickly and very smooth now w/ no lurch in the upper gears w/o the clutch which I do as desired and quite frequently.
Never read a word about RT wheels so that's news to me, and I visit plenty of forums. Shifting is very well understood and you can read all about it everywhere if you search. In short, shifting is great once you have a little experience and the bike is broken in which IMO starts at around 7500 miles, but that is just my opinion from my own RT. Fabulous, fabulous piece of work in all areas. I really like its Sport side--shockingly it handles better than the F800GT I put 23K miles on in 20 months or so, or so it seems to me. And it is so comfortable on any pavement be they tight switchbacks on up to high speed 4 lane divided roads and everything in between. I hope to have it a long time ;o)
I have an 2016. Just turned over about 5K. No issues what so ever. On the shifting - I have not noticed anything. All bikes and brands have their little nits.
But - check this out:
"For the third year in a row, the BMW R1200GS Adventure and R1200RT received Motorcycle of the Year (MOTY) Awards by Motorcyclist magazine. Editors, once again, chose the GS Adventure for its 2016 “Best Adventure Bike” category, while the RT earned “Best Sport Touring Bike” (after claiming the “Best Touring Bike” category for the previous two years). "
http://bmwmcmag.com/2016/10/bmw-r1200gsa-and-r1200rt-win-motorcyclist-magazine-awards/
The machine is an amazing piece. :dance
I am celebrating this month with my '14 RT 2nd anniversary. Just had it's 24k checkup with everything AOK. Best bike I have ever owned ! And I have had 3 previous BMWs including 2 RTs.
No problems
I'm running a 16 R1200RT. I'm pushing over 7,000 miles on her and have never had a problem. When it comes to the shifting, if you're powering on through the corners, at times she can clunk into gear. However with the Premium Package, it's more of a snap than a clunk. You never have to worry about missing a gear. It offers solid performance that you never have to worry about. I trust the bike-----I trust it with my life. I highly recommend it.
