Results 1 to 9 of 9
Thread: Will 2008 seat fit a 2009
    Will a 2008 R1200 gs seat fit on a 2009 R1200 gs?
    2008 PN# 52537667725
    2009 PN# 52537698246
    Thanks.
    Registered User wbrownell9's Avatar
    Jun 2013
    New Castle, DE
    What does the dealer say? Call the parts department of one that has lots of experience with non-new bikes. Two that come to mind are Bob's BMW and Max BMW.
    2016 R1200 GSA
    Sep 2009
    Chestnut Hill, MA
    The MAX BMW Parts fiche recognizes the second number as the correct part number. Seems like it would fit either year according to the parts fiche. See: https://www.maxbmwmotorcycles.com/fi...ts=52537698246
    A lookup of the other number brings up nothing.
    John Gamel
    2015 Ebony Metallic R1200RT
    BMW CCA 2006 - Present; BMW MOA 2009-Present
    Walt Kelly: "We have met the enemy, and he is us."
    Nov 2011
    Central Ohio
    On realoem.com, the second number is shown as a two-tone color, aluminum/black.
    The first number is not found. It is common for BMW parts to have molded-in numbers which do not correspond to part numbers.
    Click on the part numbers in the link above and it will show you the production dates of models that used the part and any superceded part numbers.
    AFAIK, the hexhead and camhead GS and GSA used the same seat shapes and pans (with some color changes) and should interchange.
    Larry
    2006 R1200RT
    Jun 2013
    New Castle, DE
    Quote Originally Posted by lkraus View Post
    ... It is common for BMW parts to have molded-in numbers which do not correspond to part numbers....
    I've noticed that too. It may be that the molded part number is just for the component it appears on. For example, the seat pan alone instead of the the whole seat assembly with pan, foam, and cover.
    2016 R1200 GSA
    Received the 2008 seat. It works/fits perfect on my 2009 GS.
    atlanta
    '04 thru '12 are the same. I've had my sergeant seat on 6 different year GS's.
    Marty Hill
    7 GS white
    Ride till you can't
    Mansfield,MA
    Going to move this to Hex/Cam,....hang on
    Mod Squad
    2009 F800GS 1994 TW200
    Registered User vancamp_b's Avatar
    Sep 2013
    Lebanon, IN USA
    Quote Originally Posted by adelatorre View Post
    Thanks.
    Yes. Same bike.
