I am ready for more farkle and am thinking about a TPMS. There are so many choices from under $100 to over $300; anybody have any recommendations?
Thanks. I will check this one out, all the ones I have seen on the internet require you to ride for 5 or more minutes to get a reading; I guess if you need air then you go home and fill up?Mobiletron. http://www.mobiletron.com/b_eng_products_view.asp?FkindNo=F000004&SkindNo=S000032&Pd_Id=3559 Very nice system. Put it in my first ('07) R1200R - as far as I know it's still working (Hi Brian!) - after about 4 years and 60,000 miles. Got a newer R1200R ('12) and put the exact same system on it..
Gives temperature and pressure. Real time. Can be read without even starting the engine.
Ordering info:
*Gary S Tsai* /Operations Manager/
*REGITAR USA, INC*
2575 Container Drive
Montgomery, AL 36109
Tel: 334.244.1885 <tel:334.244.1885>
Toll Free: 877-REGITAR (734.4827 <tel:734.4827>)
Fax: 334.244.1901 <tel:334.244.1901>
www.regitar.com <http://www.regitar.com/>
Say Hi to Gary when you call. Cost was around $120 - dunno if that's changed or not. I believe they also now have a west coast distributor too..
Guess so. Not a problem with the Mobiletron. It reads within a minute of receiving power (it's wired on a switched circuit.) No movement is necessary. I check mine in the garage, or on my driveway after pushing the bike out if I'm in a hurry. It becomes 2nd nature.
BTW - the thead-on lump ones have several drawbacks IMHO:
1. They don't measure tire temperature. That's actually really good to know. Tire pressure varies a LOT with temperature. The BMW built in system compensates for it and gives you a reading of what the pressure would be if the tire was at 20C. No aftermarket one does this. So knowing that the front is 32PSI when the tire is 55F - and that's OK - is a good thing. Once it warms up (and it can easily get up to 85F even on a 55F day) - the pressure will rise and be around 38PSI on a warm tire.
2. They provide a leak potential. Since they require the Schrader valve to be open to work - the only seal provided on the valve stem is the seal on the lump. Since the lump has to be removed to fill/adjust the pressure - chances of it developing a leak are much greater.
3. The lump has to be R&R to adjust pressure. Dunno about you - but every time I take a pressure reading as I fill a tire, I typically lose 1PSI of tire pressure. With a lump, you have to rely on your hand gauge - and it becomes a fussy job to actually end up at the pressure you want. With the Mobileton, I can read the pressure as I fill (or bleed down) the tire. No guesswork, no lost pressure.
4. The lump MAY hit your front caliper. With many of the BMW front rims with the valve in the spoke of the rim - that puts the lump right in the path of the caliper as the tire turns. Quite a few people have found this simply won't work.
5. Chance of theft? Possible, probably unlikely but some people are paranoid about this sort of thing. Some of the lumps use a tiny allen screw to lock them to the valve stem - that complicated R&R when checking/adjusting pressure - and I've heard of the allen screw rusting and becoming difficult to loosen.
That's my read on them. The Mobiletron avoids all these potential hassles, mounts nicely on the bike, seems to be long-lasting, it's backlit for night use (wish it came with orange lighting though..) and the price is pretty darn reasonable. I've had a LOT of other aftermarket TPMS setups - and this is the only one I've bought twice - and can unconditionally recommend to people. It works. Best thing I can say about it.
I read a review that said you want a TPMS to have high and low warnings for pressure and temp that can be adjusted, 12 v system, backlit display, wireless sensors, can obtain readings without driving the bike, and waterproof display. Looks like the Mobiletron has a lot of these features.
The Steelmate system has all of them except that you cannot obtain a reading without riding. You will get real time data at 20kph +. It will keep displaying the last pressure reading though.
It also has a fast/slow leakage alarm and a low battery indicator.
The sensor batteries are replaceable with CR1632 without having to remove the tire.
It doesn't show the tire temp like the Mobiletron or compensate the pressure reading for 20c like the OEM.
The sensors are low profile and do not interfere with the front caliper on my R1200Rt which has the front tire valve on the side of the rim.
The Mobiletron looks like a good system but I could not find for how much. The Steelmate costs less than $100
Last one I bought was ~$120. That's about a year ago.The Mobiletron looks like a good system but I could not find for how much. The Steelmate costs less than $100
