Results 1 to 9 of 9
Thread: 2002 R1150R - Steering Head Bolt Size?
    NC Indiana
    Anyone have any idea what the bolt / threading size is on the relatively large steering head bolt on a '02 R1150R? I need to clean both the male and female threads up and need to know what size tap / die I need. The BMW part # is 31 422 314 1 31 but the sizing info is not listed on the fische. Thanks for your help!
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    I can help you on Sunday when I get back to the shop.
    PM me if you don't get an answer
    Ufda happens..........
    NC Indiana
    PM Sent...thanks!
    Replied
    M18 x 1.5
    IS there standard or fine threads involved? I am told that there is another number ?
    Replied
    M18 x 1.5
    Is it fine thread or ?
    Paul ( similarly situated)
    #13338 PGlaves's Avatar
    Quote Originally Posted by mslacool View Post
    18mm x 1.5 means a diameter of 18mm and a thread pitch of 1.5. Course or fine thread are word descriptors but a pitch of 1.5 means the distance from one thread to the next is 1.5mm.
    I am not used to looking at 18mm diameter fasteners. I know that at 8mm 1.5 would be course and 1.0 would be fine, but have no real idea at 18mm.
    Mansfield,MA
    I find it complicated-
    This example may help-
    What does M8 1.25 mean?
    For metric fasteners, you will see a M8 x 1.25 or an M8 x 1. For thread pitch, the distance between two points is the second number meaning the higher the number the fewer threads there are. This means the M8 x 1.25 is the coarse threading and the M8 x 1 is the fine thread.
    Metrically threadrically challenged OM
    Mod Squad
    2009 F800GS 1994 TW200
    Gerard jagarra's Avatar
    Aug 2016
    Reno, NV
    When you get to large dies they can get pricy a real handy solution to your issue is a metric thread file. I googled for one Amazon lists one with 1.0, 1.25, 1.5 and 2.0 for about $15.00. These work great for cleaning threads, especially on points where you canít access a die.
    1994 R1100RS-(5/93)-,1974 R90/6 built 9/73,--1987 K75S,--1964 Triumph T100--1986 Honda XL600R
    Registered User jnrugg's Avatar
    Sep 2007
    Danielson, Ct.
