Results 1 to 6 of 6
Thread: Go-No-Go Valve adjustment feeler guages Oilhead
    Aug 2006
    Scranton, Pa.
    Looking for a set of Go-no-go feeler gauges for my 96 oilhead. Seem to be lots of sets but none has the .30 gauge
    Thanks,
    3hawks
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Not sure how those would serve you.
    To do a proper oilhead valve adjustment you need 4 feeler gauges at once.
    http://advrider.com/index.php?resources/ovad-v2-2.43/
    Ufda happens..........
    Registered User K7GLE's Avatar
    Apr 2016
    Seattle
    I bought two cheapy-cheap (like $4) of the fold-up sets (like a pocket knife arrangement) that use a nut/bolt as the hinge, pulled out the blades I wanted, wired each same-sized pair together loosely so I'm not trying to hold them all at once, then use a couple of pieces of string with a bulldog clip at each end to fasten the gauge sets to the bike (so if they fall out they don't land on the floor). It just now occurs to me I should wire in a no-go size to each pair as well.
    Don't think I've ever seen one of these sets that doesn't go up to at least .36. They typically put the thickest one at the "light" end to protect the thinner ones.
    - Glenn
    2000 R1100RT (current)
    1982 R100RT (traded)
    1970 BSA A65T, 1969 Honda CB350, 1967 Honda CB160 all fondly remembered
    Jerry Emhoff
    Oct 2007
    southwest Michigan
    Beemer boneyard has a set of 4, 2-.15 and 2- .30 for 16 bucks
    Winter is coming
    I like the set from Beemer Boneyard. I also have two sets of the Snap On Metric feeler gauges. These cover most any situation that
    I'm likely to encounter. Current prices are $12 per set (pretty cheap by Snap On standards).
    https://store.snapon.com/General-Use...--P630745.aspx
    DBLUPPR snookers's Avatar
    Jul 2010
    Niagara Wine Region
    Quote Originally Posted by Mirider View Post
    I'll second BB
    2000 R1100RT , 2005 K1200S w/hack
    Niagara BMW Riders #298 BMWMCO #45
    "Always look on the bright side of life" (Monte Python)
