Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: Aviation Fuel Use
    Aviation Fuel Use
    Just curious if anyone has had any experience using 100 Low Lead aviation fuel in their bike. Mine, 05 1200GS seems to run better with octanes above 90. It is also nearly impossible to get 100% gasoline in the Phoenix area.
    Mansfield,MA
    Interesting question, I was going to ask if anyone was aware of the properties of current small plane fuel. The VP racing fuel I just bought was, no ethanol, from the pump was 108 octane and $10.00 per gallon. I was interested in the no ethanol aspect.
    For your bike, I think you need completely unleaded so as you don't clog the catalytic converter.
    Mod Squad
    2009 F800GS 1994 TW200
    Liaison 20774's Avatar
    <<< Disclaimer >>> Use of aviation fuel for road use is really not legal.
    That said, why would you use any leaded fuel for a bike designed to run without it?
    I recently read in an aviation magazine that the FAA is starting testing of alternative no-lead fuels for civilian aviation. The goal is to eliminate low lead avgas by about 2018.
    Apart from the fact that Avgas use is illegal in anything but an aircraft, and that it will be completely phased out by 2018, you might want to consider some of its annoying quirks:
    - 100LL will foul plugs rapidly, and probably even more in newer machines since those are designed to run very lean (Lean of Peak) and cool. Unless a critical temperature is reached and maintained in the combustion chamber, plugs and everything else tends to get caked with lead deposits as the scavenging agent cannot work effectively. Part of the 50 hour inspection ritual on aircraft is to sandblast the plugs, and scrub off larger lead deposits on the plug porcelain, otherwise the electrodes get shorted out.
    - Valves and valve guides are designed at the factory to run with or without leaded fuels. A problem can arise when valve guides get clogged with carbon and lead deposits. Most piston aircraft engines need a 500 hour inspection and valve guides reamed to eliminate these deposits. Valves get stuck and pistons hit them and break off the valve from the stem when this isn't done.
    - If your bike is equipped with a catalytic converter, it will get blocked very quickly and need to be replaced soon.
    - If you use synthetic engine oils, you will get lead deposits in the engine crankcase and clogging the journals, eventually leading to engine failure from oil starvation. If you use leaded fuels regularly, you *must* use at least semi-synthetic oils, or preferably dino oils.
    IMO, unless you have an older very high compression engine, you probably won't get any benefits from using 100LL.
    francois
    With octane, more is not better.
    You only need as much as your engine requires. Any more than that is just wasted.
    It's also hilarious that so many think ethanol degrades gasoline. It does, but not as far as octane is concerned, as ethanol is an octane enhancer.
    Octane is nothing but a measure of a fuel's ability to resist knocking.
    The fact a higher compression engine tends to knock more on a particular fuel than a lower compression engine combined with the fact the higher octane fuel prevents it does not mean it was the fuel that created the extra power---that was the higher compression. Same thing with ignition advance. You can't pour in more power unless you're talking nitro.
    Another factoid: The LL (Low Lead) in 100LL is low only in comparison to other aviation fuels. It contains about 4 times the lead that was found in automotive gas back in the day. Using leaded gas will poison your catalytic converter in addition to to the other mentioned maladies.
    My '05 ran just fine on mid grade California fuel. The bike was spec'd for an AKI of 89. I'd look as to why your bike doesn't run well using the specified fuel. Ethanol may effect your MPG but as noted by others it is an octane booster. It is possible that in your quest to get 100% gas you are getting poor quality fuel. It happens. Forget about the ethanol content for a few tanks and fill up with name brand gas from a busy station.
    Registered User cehlbeck's Avatar
    Apr 2011
    Acworth, GA
    This always makes me remember the fuel portion of the owner's manual for my 2000 Ford Mustang. I'm paraphrasing but it came right out and said that the engine was DESIGNED to run on regular gas with a rating of 87 octane (or whatever regular normally is) and that was what should be used. It warned that use of fuels with higher than 89 octane (mid grade) could cause damage and would not improve performance or fuel economy. While I don't think it would cause damage Ford came right out and said regular gas in everything except the SVT Cobra which wasn't available that year.
    Chris Ehlbeck
    BMWMOA 168990
    Chris & Donna's Motorcycle Journeys
    Apr 2011
    Acworth, GA
    Quote Originally Posted by fvrana View Post
    francois
    And if you've ever had to burn off lead deposits at runup in a Cessna then you understand why you don't want to use it in your car or motorcycle.
    Chris Ehlbeck
    BMWMOA 168990
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    Even if you remove the cat, the lead will foul the O2 sensor, slowing down its response time.
    John.
    Atwater, CA
    2015 R1200RT
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    And higher octane fuel ignites slower, the higher the octane.
    If it is compressed more (read: high compression engine) it works fine. Usually you would want at least 12/1 compression to run 100 octane.
    By using high octane fuel in a low compression engine your available power will in fact suffer.
    Ken
    -Albert Eienstein
    Oct 2009
    Torrance CA
    Quote Originally Posted by cehlbeck View Post
    Been there, done that. And I still have not found the mixture knob on my roadster!
    I does rather look like a 2 cylinder Aeronca-JAP J-99 though.
    Years ago I drove a fuel truck at Santa Monica Airport, and the mechanics told me av-gas in my bike was a bad thing.
    Scott
    2009 R1200R Roadster
    Non Ethanol is much better
    Here in Florida we can get Non Ethanol gas a the newer Racetrack gas stations. You can tell the difference in mileage, performance and temp, in my humble opinion it is well worth the extra $$$ to use it over the regular crap.
    What he said, running :better" on high octane, is in your head, unless you are racing a modified machine.
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Florida & Massachusetts
    Quote Originally Posted by Towmanjim View Post
    100LL has the ability to kill both O2 sensors and poison the catalytic converter, all in a few hundred miles.
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    Ken
    My RT has 12:1 and the new water cooled one is 12.5:1 I think.
    My Motorrad
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
