Results 16 to 30 of 42
Thread: Low beam bulb replacement for 2015 RT
  1. #16
    Mar 2011
    socal
    For those who have managed to loose retaining spring, your in luck, Beemer boneyard sells them
  2. #17
    Addicted to windshields Realshelby's Avatar
    Aug 2015
    Houston, Texas
    Unlike some other models, the Wethead RT seems to capture the spring so it cannot come completely loose. But if they do have them available that is good, but it would require removing the headlight assembly to do it. Which I have done and while bad enough it is more simple than you might think.
  3. #18
    I have a Hoshi in the RT and I have these ordered for the XR. http://www.sol2.be/Visibility/LED_ENG/Order/page.html .
    Buck in Greensboro, NC
    2013 R 1200 RT Midnight Blue - traded, 2014 R 1200 RT Ebony Metallic, 2016 S 1000 XR
  4. #19
    Aug 2014
    Lakeland,FL
    Quote Originally Posted by Realshelby View Post
    On my 07RT it takes about 30 minutes to remove the body panels, windshield then the headlight assembly, replace all the bulbs then reassemble. In the long run I think it is less aggravation and gives me an opportunity to clean areas once a year I normally can't get to as well.
  5. #20
    Sep 2006
    CENTEX USA
    Quote Originally Posted by mikegalbicka View Post
    Pretty much my method when I had my 05RT. The clip retainer was not as robust as it appears in the new picture and very easy to break. One bulb out, others not far behind.
  6. #21
    Registered User fallguy's Avatar
    May 2016
    Indiana
    bdfbeemer,
    You say you have an Low beam LED in your 2014 RT? No issues?
    If so, can you give more details?
  7. #22
    Sep 2003
    Virginia Beach
    I've done this nasty job-yes through the front from underneath. Last time this happened, I just took it to the dealer. I think the time unit is set for 12 minutes. They just charged me for the bulb. Actually, they were just gonna use the bulb I brought, but I like to support my dealer. I mean, it IS good to know how to do it at the side of the road...
    Virginia Beach
    current:16 R1200R 75 R60/6
    past: 14 R1200RT 11 R1200RT 10 R1200RT 03 R1200CLC
  8. #23
    OldBMWMaster JDOCKERY132445's Avatar
    Sep 2010
    Pleasure Island. NC
    Small hands
    After spending over an hour sweating and cursing, I gave up. My girlfriend has small hands. It took her about 5 minutes to do the task.
    Jerry Dockery
    309 N. 3rd. Ave.
    Kure Beach, NC 28449
    2009 R 1200 RT,1996 R1100RT, 1985 K100RS...too fast to believe.
  9. #24
    Quote Originally Posted by fallguy View Post
    bdfbeemer,
    No issues. This is the second oneI have tried. I didn't have any luck with HID set up.. The first led had copper ribbons for heat dissipation. That was a pain in the ass. The heat sink is self contained in the current one. I had to hollow grind the inside if the plastic cup but other wise plug and play . No canbus issues. I am trying a different brand on the XR just to see if there are any differences. I am waiting for them to arrive in the mail.
  10. #25
    May 2016
    Indiana
    Thumbs up
    So your using a Hoshi H7 on the low beam and you don't get any dash lights when you switch from hi to low beams?
    This is interesting.. your the 1st person I have heard from that got a LED to work..
    I might have to order one..
  11. #26
    I have used two different brands abs no error codes. A lot of people have used them on XRs.
  12. #27
    May 2016
    Indiana
    Have or did you notice any weird light patterns using the led in the RT? I've heard some headlight assy dont work well with Led's and they have shadows or dark spots. Do have any pics of the install?
    Sorry for the questions, but I really want to do this to my headlight.
  13. #28
    Jun 2015
    Tacoma, WA
    LED Bulb Replacement
    I have been using this replacement for 1-1/2 years and 17K miles.
    I commute year round and it has been a great replacement. All of the lights on my RT now have the same color range except the high beams.
    Scott
  14. #29
    I just switched out the low beam bulb successfully, it seems. It took me maybe half an hour and turned out to be much more pain-free than I thought. The harness plug I did have to fight, but it finally gave up. I got one side of the clip off and then practiced putting it back on a few times while it was fresh in my mind. After monkeying with the bulb it eventually clicked into place, then the clips actually seemed to find there way back easier than I thought they would. Anyway it looks like I saved myself a 200+ mile round trip to the dealer.
  15. #30
    May 2016
    Indiana
    Ok, here is some feed back from my Hoshi H7 Led canbus headlight install and my thoughts..
    #1, you have to remove the head light assy.. There is no way to get the hold down springs clipped with led installed without using tools (small needle nose pliers) and its still a pain.. (3 hr job)
    #2. There is about 75-100 screws and pieces of plastic to remove to do this. ( be prepared to clean everything while its apart)
    #3. Change your high beams out at the same time if you haven't already ( it takes 2 min when everything is apart)
    Final conclusion, I'm not impressed with it all.. The light pattern seems to be wider (good) but fades over distance (kinda washed out and don't carry as far as my Phillips extreme +130) Its very white light, seems like maybe a slight blue tint tho.. Maybe that's just me. Road signs on back county roads light up and honestly almost blind you as you pass them.
    If I had seen this before on a RT, I probably would not have done it and there is a high possibility I might go back to my regular H7 ( Phillips or PIAA) halogen bulb. If I'm ever on a trip and have this LED fail there is no way to change it in a parking lot and as a bonus nobody tells you about the LED emits EMI and messes with my radio and all I get is static when the head lights on.
    If anyone is around the South Indianapolis area and wants to check my LED out in an RT let me know. I have one extra LED because they come in a set of 2.. and then again I might have 2 if I take mine back out.
    My over all conclusion is I'm not sold on it for the swapping pain and radio issues it causes. On the plus side, night or day my headlight is almost 2 bright to look at. You can see my head light from a long distance. But the actual light on the ground in front if you isn't that impressive. After Installing I have been high beam flashed several times now. I even have the light adjusted down.
    I might have missed something, so if you have questions please let me know. This is all just my personal opinion.
