No issues. This is the second oneI have tried. I didn't have any luck with HID set up.. The first led had copper ribbons for heat dissipation. That was a pain in the ass. The heat sink is self contained in the current one. I had to hollow grind the inside if the plastic cup but other wise plug and play . No canbus issues. I am trying a different brand on the XR just to see if there are any differences. I am waiting for them to arrive in the mail.bdfbeemer,
You say you have an Low beam LED in your 2014 RT? No issues?
If so, can you give more details?
I have used two different brands abs no error codes. A lot of people have used them on XRs.So your using a Hoshi H7 on the low beam and you don't get any dash lights when you switch from hi to low beams?
This is interesting.. your the 1st person I have heard from that got a LED to work..
I might have to order one..
Does the connector need to be pinched to remove it? Does the connector pull off in the direction of the rear of the bike
Here are videos of my 07RT bulb removal showing the spring clips.
https://m.youtube.com/watch?v=fRpmO5YomC4
https://m.youtube.com/watch?v=h55ApNDRKMY
