So I finally got around to finish the last part of my 24k...fuel filter replacement...
Disassembly of the tank and internals aren't too bad...I was curious if the filter had ever been replaced.
Sure enough, date on the filter was Dec of 1998!
I used flexible internal fuel hose kit from BMW Boneyard to bypass internal filter...worked perfectly, just had to trim length and adjust to make sure it didn't interfere with fuel float...put everything back together, all seemed well, until I re-routed the fuel hose to the filter...seems I'd reversed the supply and return lines...lol
Once straightened out, mounted a fresh factory filter and mounted it tucked away under the side of the tank...beautiful fit...checked for leaks and took it for a rip...looks like I wasn't getting good flow through the old filter...
Bike actually revs quicker and throttle response is better...with the crappy fuel we have here, now it'll be a 10 minute job to replace the filter every other year...highly recommended process if you are some what mechanically inclined...
Bottom line, replace your filter if age is in question...
