Results 1 to 13 of 13
Thread: 2008 R12RT - changing lower spark plugs
    Kindly curmudgeon W7lej1's Avatar
    Aug 2006
    Spokane Valley, WA
    Hi All,
    This has probably been previously discussed and I just missed it.
    Can anyone point me to a suitable thin-wall socket (it would seem, VERY thin-wall) for extracting and installing the lower spark plugs? My Craftsman deep socket walls didn't look very thick, but wowsers, that's tight in there.
    Thanks for any suggestions and guidance.
    Marty
    Marty in Spokane Valley, WA
    '79 R65 - the rolling running project bike
    '08 R12RT - "new scoot"
    Sep 2006
    CENTEX USA
    Hey Marty,
    try this thread, I have collected a few thru the years, some fit, some have been ground down
    http://forums.bmwmoa.org/showthread....rk+plug+socket
    Aug 2006
    Spokane Valley, WA
    Hey Marty,
    Thanks, Steve!
    Marty
    Registered User David13's Avatar
    Nov 2011
    Utah
    Your best bet is to grind one down.
    They may read "thin" or anything like that. The ad may say really thin or ultra thin.
    But once you get one stuck in there they can be very hard to get out.
    So I think grinding is the easiest.
    dc
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    Quote Originally Posted by David13 View Post
    dc
    That's what I did. Works fine now.
    My Motorrad
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
    Albuquerque, NM
    The BMW special tool works really well.
    Kent Christensen
    21482
    Still plays with trains. tinytrains's Avatar
    Oct 2009
    Torrance CA
    Is the bottom plug well tighter than the top one?
    I have pulled the top plugs with no problem, but have not tried pulling the bottom ones yet.
    Scott
    2009 R1200R Roadster
    Jul 2004
    Charlottesville, VA
    The BMW shop tool works best. It is very thin, has retention, and is long enough to work without any extension. I wish BMW sold one like this for the newer engines.
    The Snap-On socket fits well also. Only use it with a locking extension (same with any socket IMO).
    The old 1100/1150 toolkit tool works well, too. No retention, though.
    Anton Largiader 72724
    Tech articles - YouTube
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    I have an ITC 16mm deep socket that works perfectly for both spark plugs on my 07 RT
    I never noticed that the top and bottom ones were different.
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
    Albuquerque, NM
    Quote Originally Posted by Dann View Post
    The spark plugs are not different. Just less clearance around the lower ones.
    Kent Christensen
    21482
    Dec 2013
    Laval, QC, Canada
    That's what I meant...
    Daniel
    Jul 2004
    Charlottesville, VA
    FWIW the BMW 12 3 510 tool (83 30 0 401 695) is 20.5mm diameter. The Snap-On 5/8 spark plug socket (S9706KRA) is 21.15mm. The BMW toolkit tool from the R11xx era (71 11 2 316 193) is about 21.2mm. I haven't seen the toolkit tool that was made available for the Hexheads, but it is different.
    Jul 2004
    Charlottesville, VA
    And, as an anecdote, a customer brought me a TwinSpark 1150 into which someone had installed 11/16" plugs in the bottom. I turned an 11/16 spark plug socket down to 21.85mm (there was 0.75mm wall thickness left at the corners) and it would just go in far enough to get the plug out but it would not slide in.
    If you want to turn down your own socket, or buy one, I'd make sure it was no more than about 21.2mm based on the numbers I posted a few minutes ago.
