Results 1 to 2 of 2
Thread: 94 rs gear position stuff
    Jan 2016
    Central Illinois
    I have a 94 RS and the gear indicator is very erratic how the thing works I do not know can adjustments be made I do not know can it be easily fixed does the indicator being goofy indicate something bad in transmission and finally I have not looked to see if their is something to fiddle with hit with a hammer unplug reboot it is not the end of the world if it does not work but nice when it does
    Odds are very high you just have moisture in the connector in the bundle from the transmission. Trace the wire up from the transmision to the left side by the frame, disconnect, and clean and dry the connection.
