Results 1 to 8 of 8
Thread: washed 1100 rt
    washed 1100 rt
    washed RT today.. then went to top off oil, noticed a little water buildup when i took filler plug off..
    there is a chance a little water got into the drain, plug.. when i say little, just maybe a eye drop .
    what do you think?
    Liaison 20774's Avatar
    Should be OK...sounds like as much moisture that naturally gets in due to condensation. A few good rides should heat up enough to get the water out of the engine.
    Left Coast Rider
    Nov 2011
    Obviously a complete tear-down is in order. Yes, I'm kidding! You'll be fine.
    thanks , I'm sure there is plenty of condensation at the beginning of riding season after a long winter.. non heated garage..
    Push it out to the curb
    What was the address again? Yeh it might be major problems with moisture in the oil so cut your loss.
    ONLY KIDDING!!!!!!
    Ride it a little and if it makes you nervous change the oil & filter and forget about a couple drops of H2O in there.
    thanks again.. after being stranded with a FD failure everything makes me nervous..
    Mar 2010
    Vancouver, B.C. Canada
    Quote Originally Posted by RICH7196 View Post
    Don't worry. Go ride it. Any water in the oil will boil off right quick once she's nice and warmed up.
    Bmuused BMUUsed's Avatar
    Apr 2012
    Lemont, Illinois
    You washed it? Isn't that what rain is for?
    At the tender age of five, a bear told me that only I could prevent forest fires. Why I was chosen, I'll never know.
