Results 1 to 15 of 18
Thread: Tool Kit recommendations?
    Registered User skibumwi's Avatar
    Jul 2016
    Milwaukee
    I'm looking to pick up a decent tool set for general maintenance on my 2016 RT, it could be broken up into a travel kit and supplementary shop tools.
    I've run across the following on the inter-webs and was wondering if anyone could recommend either one, or suggest an alternative.
    http://www.beemershop.com/Merchant5/..._Code=MTT00014
    http://www.revzilla.com/motorcycle/c...h-bmw-tool-kit
    Thanks,
    Ski
    Mar 2011
    socal
    Outside of your shop very little can be accomplished on newer bikes
    My tool kit is very basic
    Snubby snap on ratchet screw driver with the common torx bits, a Phillips and flat blade all stored in the handle
    Leatherman tool
    Mini air pump/with flat repair kit
    1/2 dozen 12 inch zip ties
    Combo socket to remove front axel
    Spare spark plugs along with the thin walled socket
    Most of the tools fit in a small zip pouch stored under rear seat
    In real life, have only had to use the air pump, and that was for a buddies bike
    Nov 2011
    Central Ohio
    Another option: http://www.advdesigns.com/ulcobmwr1gsg.html
    Add a small compressor and a sticky rope patch kit for flats.
    Larry
    2006 R1200RT
    Mar 2010
    Wills Point, TX
    Quote Originally Posted by lkraus View Post
    Dido, this is what I carry. The kit is pricey but the tools are good and complete.
    Jay
    ...and do you plug the compressor into the accessory jack or do I have to install a jack directly off the battery terminals?
    Ed Kilner #176066
    Nov 2011
    Mississauga, ON
    Quote Originally Posted by watermelon View Post
    It will draw a fair amount, so a fused direct connection would be best.
    The 2 dealers I have bought bikes from here in Canada both supplied the bike with an ASA dongle on them. 2011, 2015 but different dealers.
    Ed
    2015 R1200RT; 2011 R1200RT RIP; 2000 Triumph 900 (sold)
    http://triumphantsblog.blogspot.ca/
    Mar 2011
    socal
    Best to wire a fused powerlet connector direct to battery, on my 15RT I placed it behind the battery on right side. A better place would be next to the current outlet on upper right side
    Two additional advantages to a direct wired outlet 1 no issues with canbus when on charger 2 your heated gear won't trip the canbus
    Mar 2010
    Wills Point, TX
    I plug it in the standard BMW outlet with no issue. That's not the same on a GS, the Can Bus will shut down. I carry the Aerostich compressor. The bike has to be on (it's running) for the outlet to work but that's not an issue since I don't want to draw from the battery alone. I do have the ability to direct connect to the battery, it's how I connect my Battery Tender. You never know how it's going to be used when helping others, good to have options.
    Jay
    Nov 2011
    Central Ohio
    My Slime pump is labeled as 7 amps. With power plug adapters, it works fine from my RT's 5 amp accessory socket, at least at the tire pressures I use (<44psi). It might trip the ZFE breaker if I tried to use it's full 300psi capability.
    Larry
    2006 R1200RT
    All of the above tool kits look good - but expensive. You can assemble a kit from a good hardware or big box store cheaper. The kit bags are nice. I am hauling lots more tools in a travel ditty bag. Roadgear also (at the rally) will have nice tool roll-up bags.
    Mar 2010
    Wills Point, TX
    The RT is 10 amp total, the GS, GSA, R,RS is 5 amp (source Haynes Manual) Like I mention in my above post, my air pump shut down a GS canbus while works fine on my RT.
    Jay
    Nov 2011
    Central Ohio
    Sorry, forgot where I was.
    Early R1200RT sockets are 5 amp. I think the boost to 10 amp occurred with the Camhead introduction in the 2010 model year.
    Larry
    2006 R1200RT
    Registered User reg26's Avatar
    Oct 2015
    LI,NY
    I purchased this kit for my KLR but carry it with me on my RT for longer trips. Great quality and only &=$100 bucks right now
    https://www.youtube.com/watch?v=D4JV...em-subs_digest
    Nov 2011
    Central Ohio
    Quote Originally Posted by reg26 View Post
    That's a nice kit, with some ingenious tools. Can that little ratchet provide the torque needed for the T-50 wheel bolts?
    Larry
    2006 R1200RT
    Oct 2015
    LI,NY
    No definitely not. I believe he states in the video 25ftlb max or something like that. Still got to carry tools for tire removal
