Results 1 to 10 of 10
Thread: Recalled Snowflake?
    Fenwick, Ontario Canada
    Recalled Snowflake?
    I have a Recalled Snowflake Front 19" is it worth anything? Or is it a wall hanger?
    I don't have the bike it came from, so I can't take it back to BMW for a replacement.
    Maybe I will make a clock out of it! ;>)
    I can't sell it as a useable wheel.
    Ambassador Emeritus BMW MOA Ontario Canada
    Niagara Riders
    Knights of the Roundel #333
    1977 R100RS, (Retired) 1993 R100GS
    Liaison 20774's Avatar
    Darryl -
    I wouldn't be too sure about BMW not working on the wheel. I'd certainly ask...you never know. As it is now, the answer is NO, and it still might be NO even if you ask, but...
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    I just picked up an R80RT, technically an R80/7 that is a huge basket case. It's needing loving right to the bones. It has Snowflakes and one of the reasons why I was attracted to it. It doesn't look abused/dropped but very neglected.
    Can someone fill me in on the recall?
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    “The major civilizing force in the world is not religion, it is sex.”
    Registered User kioolt's Avatar
    Maryland
    If I recall correctly the wording of the recall went something like this. "On high mileage bike that have been ridden on rough roads there is a chance of front wheel failure." The fix was to replace the front wheel with one that had reinforcement added to it. It is a noticeable difference in the two wheels. I don't know exactly how to describe it.
    2004 R1150RT 186,800 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 422,400 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    Quote Originally Posted by dieselyoda View Post
    It's for front wheel 19" wheels up to about 1982 bikes. Check the link in my signature line and find the recall section. There's a link there to Snowbum's website which has all the details. There's also a link there to the federal recall campaign if you want to read all the tiny print!!
    Mar 2013
    No!!
    Crap, mine is an original Snowflake.
    What can I do now? What are the chances that I can get a replacement under the recall?
    Take bike and wheel to a dealer. They are supposed to honor the recall as it should never expire. Not sure if it was on that website, but there is a letter to Canadian dealers that can be referenced so being "up north" shouldn't be an issue.
    As Snowbum probably wrote, be sure that the bearing replacement is done correctly...there must be proper preload on the bearings.
    I, too, liked the snowflakes.
    "The difference between death and taxes is that death doesn't change every time congress meets." - Will Rogers
    Mike V. #30064 30064's Avatar
    May 2006
    San Diego, CA
    See attached bulletin regarding the Snowflake Replacement.
    I've never experienced a failed recall wheel. I have over 80k miles on mine with no fractures, or damage of any kind. If you do decide on the replacement direction make SURE the dealer has CORRECTLY lubed and preloaded your wheel bearing in the replacement wheel. As Kurt has mentioned ... Chances are you're in more danger from a replacement wheel hub and bearing stack that has not been properly set-up through the replacement process than the original wheel exploding on you.
    Attached Files Attached Files
    Mike V. / San Diego
    MOA#30064 / ABC#11027
    78 R100/7 [orig. owner] / 81 R65 [restored]
    ABC-MOA-AMA-VBMWMO / http://tinyurl.com/4df7hgs
    Still Wondering mika's Avatar
    Aug 2004
    Fly Over Land
    http://www-odi.nhtsa.dot.gov/owners/...prod_ids=27521
    FWIW : This is a link to the NHTSA recall for the wheels.
