Results 1 to 3 of 3
Thread: Oil in the exhaust
    Dec 2014
    Alabama
    Oil in the exhaust
    My 2011 R1200GS took a slow speed fall in the grass yesterday. I got it shut off within probably 3 sec., after that on the way back home I could smell brunt oil, I could see a little smoke coming from the muffler below engine. Only thing I can think is some oil went through the exhaust valve when it was laid over. Would that be the correct way to think and is that some what normal or is there something I should check. Thanks.
    Mansfield,MA
    I wouldn't worry. It's normal for the rider to be a bit "hypersensitive" to "new" noises or smells after the bike take a "nap".
    Mod Squad
    2009 F800GS 1994 TW200
    Still plays with trains. tinytrains's Avatar
    Oct 2009
    Torrance CA
    More likely some oil collected in the rings of the downward cylinder. No problem as it will burn out.
    You should see my K75 when left on the side stand when hot. Free mosquito abatement!
    2009 R1200R Roadster
