BMW Triumphant
Ed Kilner #176066
This link may work and then you could download an Excel spreadsheet (use Excel or Google Sheets (free).)
https://docs.google.com/spreadsheets/d/1GMtju5P-wOhImg8GdLiv3qkBMUTnsP9e_NdsWYw2IWU/pub?output=xlsx
When open, you can input your desired inflation, say 38psi, and the current ambient temperature. You will see the calculated pressure to which you should inflate the tire.
The manufacturer's tire recommendation is valid for 20 degress C at sea level. The spreadsheet does correct for other temeratures but not altitude.
Do let me know if you encounter any difficulties accessing the spreadsheet.
