Results 1 to 5 of 5
Thread: Battery pigtail attachment
    Dec 2007
    Midwest
    My brother just purchased a 2014 C650GT. Is battery located such that a pigtail for charging can easily be attached?
    2008 RT
    MOA #46783
    Jeff Wilson life member Justscootin's Avatar
    Jun 2012
    Richmond Hill Ontario Canada
    Yes it is
    Quote Originally Posted by Motodan View Post
    Jeff
    A bad day on the C650 GT scooter is better than the best day at work
    Mar 2011
    socal
    Battery is very easily accessed through upper right forward panel,
    I installed a fused Powerlet plug just above the right glove box
    Used for charging and heated vest
    Registered User racerjack's Avatar
    Apr 2006
    The Villages, FL
    Battery Charging
    Hello,
    As I read the Owners manual, you must use appropriate battery charger through onboard outlet. If you charge directly to the battery, you must disconnect the battery from the bike. Look at the information copied below and straighten out my thinking.
    Charging connected battery
    Charging the connected battery directly at the battery terminals can damage the motorcycle electronics.
    To charge the battery via the battery terminals, disconnect the battery first.
    If the multifunction display and indicator lamps fail to light up when you switch on the ignition, the battery is completely discharged (battery voltage be- low 9 V). Attempts to recharge a completely discharged battery through the onboard power socket can damage the motorcycle's electronic systems.
    Always charge a completely drained battery directly at the terminals of the disconnected battery.
    Only charge connected battery via additional onboard socket. The additional onboard socket is only available as OA. Comply with operating instructions of charger.
    Jack
    Mar 2011
    socal
    Wifes scooter has had charger attached in the way I described above for almost 3 years, with no adverse effects
    In fact bike came from dealer with a set of pigtails attach d directly to battery.
    This is the fourth bmw I have wired to bypass the canbus system
    By wiring a Powerlet plug direct to battery you are able to run a tire compressor and heated gear which you might or might not be able through canbus
    FYI we use optimate 4 chargers exclusively
    Jim
