Hi,
I've done all the 650 miles oil service to engine and final drive with no problems at all.
However, I can't find the drain plug for the transmission. The filler cap is easy to find on the left side up but there is no drain plug to be found...
I was wondering if this new model uses the same motor oil for the engine and gear box, since the very bike manual doesn't even refer to exchange the gear box oil...
Can you please help?
Thank you.
Thank you.
