Results 1 to 15 of 25
Thread: Stalling!!
    Registered User temesvar's Avatar
    Dec 2015
    Windsor,ON
    Stalling!!
    I read the thread about 2011 RT stalling/bucking/misfiring.
    My 2008 RT ,with 19K km is just at the first stage:stalling!
    No bucking nor misfiring, at lest not just yet
    I have the bike for about 6 months/2000km. Never a problem
    until a week ago when, in traffic, the motor just stopped. No
    warning light, no sign of power failure. Just like if it ran out of gas, or switched the ignition off.
    Pulled over, desperate and upset. thinking as what will do,to take the bike home.
    After about a min. figured i will try one time to start it, before pushing it somewhere aside.
    It started like nothing was wrong! For a week had no problem, until just yesterday
    when it stalled again. Same way, just stopped! Pulled over, and restarted it with no problems.
    No bumpy road, tank about half full (or empty...) Am not sure if i refilled since it first happened.
    Any suggestions welcome.
    Rocky Bow BMW Riders #197 KenDittrick's Avatar
    Apr 2008
    Calgary AB
    Do you know if the FPC Recall has been done on your bike? This does sound like one of the symptoms.
    Ken Dittrick
    2008 R1200RT (Biarritz Blau)
    Excuses are the rocks upon which our dreams are crushed - Tim Fargo
    Dec 2015
    Windsor,ON
    Quote Originally Posted by bogthebasher View Post
    No Ken, i don't even know what that is..
    However, am about to ask the previous owner if he had experienced this as well about that recall...
    Aug 2014
    Lakeland,FL
    Call your dealer and give them your VIN and they can see what recalls are outstanding. Specifically they can see if the FPC (fuel pump controller) has been done yet.
    Nov 2011
    Central Ohio
    There was a recall for the 2006-2008 GS, but AFAIK there has never been a recall of the fuel pressure controllers for the RT. Quite a few failures and replacements, but generally all at the owners' expense.
    Though the symptoms do match a FPC failure, I thought that by 2008 BMW was using the more reliable black model rather than the failure-prone silver version? Maybe not...
    A Google search will tell you more about symptoms, and temporary bypass cables.
    Larry
    2006 R1200RT
    Sep 2006
    CENTEX USA
    Had added this link in another post.. start at post #1
    It is a Fuel Pump Controller linked to the pump in tank
    http://forums.bmwmoa.org/showthread....FPC+controller
    Apr 2008
    Calgary AB
    Thanks for adding that thread - I knew it was somewhere.
    Ken Dittrick
    Dec 2015
    Windsor,ON
    Thanks Steve, that thread sure comes in handy!!
    Now i just need the time to figure out how
    and when to get to it
    Dec 2015
    Windsor,ON
    Since you also have a 2008, did you have to take yours in for this recall?
    Was just wondering. The PO says no recall for FPC, only for the
    fuel tank seal and rear wheel flange. At least, that is what he had.
    Thanks, Ken!
    Sep 2006
    CENTEX USA
    Quote Originally Posted by temesvar View Post
    You can see it looking down on left side as sitting on bike.not much tupperware to remove to get to it, the left shark nose if any at all should open it up to get to the screw on a RT I recall. You can at least see what color it is
    The FPC was replaced as a warranty issue and not a recall. My 09GSA failed after the warranty ran out, I bought one and popped it in.
    Dec 2015
    Windsor,ON
    Can you suggest where to buy it from? The bike stalled again today, in plain traffic. Am not riding it anymore unless have it fixed. Will try replacing that first, as it very well may be the cause of the problem. As for a GS 911, is there any in particular i should get? noticed there are a few kinds on eBay.
    Thanks again,
    Registered User C172MyP51's Avatar
    Sep 2011
    Hershey, PA
    My 06 has stalled a half-dozen times over the years. Can't really recall a pattern, except that I was stopped. No big deal...just pressed the button again. I'm not saying don't worry about it, get the recalls done, but I wouldn't lose too much sleep over it if it restarts easily.
    -Scott
    Hershey, PA
    IBA# 41,645
    2013 R1200RT
    2006 R1200RT (deceased 6/2018 - Final drive failure)
    Dec 2015
    Windsor,ON
    Quote Originally Posted by C172MyP51 View Post
    -Scott
    This bike is rather new to me, have it for about 6 months and put on about 2000km. That is because riding season is just about to start! Had no issues with it so far, but 3 times in last 2 weeks. Am not even sure that is the problem. As a FPC recall, was never one for RT, for what i understand.
    Sep 2006
    CENTEX USA
    Thanks again,
    I would eyeball the FPC for visual clues first, like the thread discusses, like corrosion. If it is an anodized black unit...might not be your issue.
    It's not an aftermarket part, a dealer is your choice.buying a used one is sketchy , though I know they are available.
    As far as the GS-911...buyer beware if you buy a knockoff China clone.
    There are some used yellow, non wi-fi units available that will work on your bike. Most are being sold as the '14 and newer bikes require the new red wi-fi unit.
    US vendor on west coast:
    I would run the unit serial number by them to check it's status if that is possible
    https://www.beemershop.com/
    http://www.hexcode.co.za/
    Dec 2015
    Windsor,ON
    Easy enough to get to it, not as bad as i thought.
    Inside the well was enough water to make a baby duck happy!!
    Hard to believe, but this is what i found:!!!
    Thanks to all that responded, and especially henzilla and racer7
