Results 1 to 12 of 12
Thread: Time for a new front tire on my rig
    Registered User DRRAOULDUKE's Avatar
    Northern Illinois
    Looking for ideas. I have a 1974 R90/6 with a Ural sidecar. Ural rig could also use a new skin as well so I guess I am looking for two recommendations.
    Thanks in Advance,
    Dr. Raoul Duke
    1999 R1100GSA
    1974 R90/6 with Ural Sidecar
    "The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs. There's also a negative side."
    ‘«ŰHunter S. Thompson
    Registered User 6322's Avatar
    Mar 2012
    Riggins, ID
    What are your wheel sizes?
    Gary Phillips - #6322
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '00 R1100RS
    Mar 2012
    Riggins, ID
    Heidenau advertises sidecar tires in 18" & 19", for both highway and dirt applications. If you were running 18" Metzler has their K Block.
    Northern Illinois
    Front & Sidecar Rig Replacement tires
    My current front tire on the 1974 R90/g is a Metzler 3.25 X 19 MC 54V and has side cracking. Probably like to replace the tire on the Ural sidecar as well.
    Any recommendations besides the OEM tire??
    Thanks in Advance,
    Dr. Raoul Duke
    1999 R1100GSA
    Mar 2012
    Riggins, ID
    Just do a search for Heidenau sidecar tires. Their K28 and K29 may fit the bill. If your Ural hasn't been modified, it should be a 19" wheel. Many have been modified to take an 18", BMW rear wheel. That way if you have a flat on either the rear of the bike or the boat, you only have to carry one spare to fit both. That's why I asked about size.
    In either case Heidenau should have a tire to fit. There are other motorcycle tires that would fit but a motorcycle has a different purpose, mainly a rounded profile for leaning in the corners. They will work but don't last as long as a sidecar specific tire. A sidecar tire is built with a more squared off profile putting more surface on the road, similar to a car tire. Sidecars also put side load on a tire so changing out your weather checked tire(s) before they fail is a good call.
    Good luck and ride easy,
    gp
    Boxers uber alles sagerat's Avatar
    Jul 2006
    Central Oregon
    Duro 308s are what I'm running on my Ural. Heidis (I have K-60 Scouts on my GSA) are spendy, but wear a long time. The sidewalls are as stiff as an ironing boars and a royal pain to mount and dismount if you do your own tires. Buddy runs Heidis on his Gear Up.
    Gone are the days of the $25 Uralshina tires.
    Pismo Beach, CA
    Ural equipped the "Retro" model with 18" wheels on all corners. It was set up for disc brake.
    +1 on Duros
    Duro 308
    Duro 307 if you're looking for something a little more "off-roady".
    They're both in the $50-80 range. Which isn't too bad.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Registered User vetsurginc's Avatar
    Apr 2005
    Parkland, FL
    I'm running an Avon sidecar tire on my Ural (4x19). More of a block pattern. Wearing well and is going to last through 2 pushers. Good grip in wet (this is a relative term comparing to Duro's). If you have same size at each corner consider switching worn tire to sidecar. My experience is sidecar tires last a long long time.
    Jul 2006
    Central Oregon
    Duro 308s on my '04 Ural and I've run Uralshinas in the past.
    Pismo Beach, CA
    As an aside... are the Duros "hand-mountable" ?
    I just had a flat on my /5 rear tire. The tire is a Bridgestone S11 Spitfire; a great tire, but I couldn't even get the bead broken down off the rim by hand. Finally bit the bullet and took it to my local independent shop that has a changer.
    Even though the old Continental K112/RB2 pairs were squirmy at best, at least you could change them by the side of the road if need be.
    Lew Morris
    1963 Dnepr
    Astatula, FL
    Quote Originally Posted by lmo1131 View Post
    The old tube type tires had much softer sidewalls. with the wide spread advent of tubeless rims, almost all tires now have stiffer sidewalls for tubeless compatibility.
    I'm sure it's not because we're gaining chronological experience........
    Bob Weis
    Bikeless! 2004-bmw-k12rs-hannigan-Sold!
    Jul 2006
    Central Oregon
    The Duros are hand mountable when left on lawn on warm summer days; winter in the garage is an ugly wrestling match.
