beemermyke
Today i got a 2016 R1200 GSA after threatening to for years. Great bike on the 150 mile ride home, but an odd thing happened shortly after I got it back to the house. It's the keyless ignition (FOB) and it has the retractable key for the panniers and seat lock. It worked fine on the panniers, but it is now jammed in the seat lock after I removed the front and back halves, and locked them back in place. I read the booklet; turn it CCW to remove the front, CW to remove the aft. The key slot, prior to inserting the key was vertical (straight up and down). The stuck key is about a 45 degree angle, so it won't release. Furthermore, the seats will no longer release either. Is this a known issue with the seat locking mechanism? I put a call into the dealer and left a message, but I'm hoping someone has experienced this and maybe has a solution.
