Results 1 to 5 of 5
Thread: K75/100RT Fairings
    WC Indiana
    K75/100RT Fairings
    Are they interchangeable? Can an RT fairing be put on any K75 without any special adaptors, etc.?
    Thanks, JON
    Focused kbasa's Avatar
    I think the tank the RT uses is different than the regular K series tanks.
    Dave Swider
    Marin County, CA
    Blocking the slow lane
    Edwardsville, IL
    Like Dave said, the gas tank is different. But the K75RT model also uses a different radiator than the std K75, mounted in a different fashion. You could probably get away with the std radiator, but I don't know if it'll mount up correctly.
    Jon Diaz
    BMW K75
    MOA Ambassador Emeritus
    CustomSarge
    RT <-> std
    I thought all K gas tanks (exc '85:mount) are the same. But I'll yield that the K75RT looks a little different, I'd need an A:B picture.
    On K75, the RT radiator is wider, enough that a std shroud doesn't want to fit (but will). The RT also has a removable bracket that moves the radiator base out ~1", to align to the grille.
    As I 'mem, the only wiring issue is turn signals.
    I put a K75RT back to std, but didn't use the stock headlight ass'y.
    I put K100RT bodywork on a std, the Only issue was turn signals.
    The RT fairings sure look the same. G.H. <<<)))
    On the Road
    On the outskirts of the thriving metropolis of Burgin, KY
    For questions like this I usually go to the Max BMW online parts fiche. Look at the part number for each model in a given year and see if its the same. This worked well when I was looking for KLT mirror housings.
    HTH
