Results 1 to 12 of 12
Thread: 15 GSA does not start on first attempt
    Hi, I have a 2015 GSA and it does not start on first press of the starter switch, but ALWAYS on the second press.. Seems weird to me I have been putting up with it but now I worry something maybe screwed up. Does anyone else have this problem?
    Happens when engine is hot or cold.
    Mansfield,MA
    Welcome to the forum!
    There are many Members with the new Wethead, hang on and I'll bet you can get an answer.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Try hitting the starter right after you turn the key, don't give it time to cycle. worked for me for weeks, then it did not work, so i let it cycle and it started, i think they learn as they go.
    Registered User BMARC153920's Avatar
    Dec 2014
    Orange County, NY
    Quote Originally Posted by 2010rt View Post
    Yep this, same exactly problem, same exact solution. Issue eventually resolved itself.
    Sent from my KFSAWA using Tapatalk
    Quote Originally Posted by BMARC153920 View Post
    Thanks for info, will try this out - weird how this solves it, I thought I might be related to the injectors priming with fuel getting out of sync if that's even possible
    Dec 2014
    Orange County, NY
    Quote Originally Posted by Jotski View Post
    I and a buddy with the same year bikes both had the same problem and ran dozens of tests over different temps and times of day to the point where we could reproduce and avoid this issue on demand.
    We came to the unofficial conclusion that either the fuel pump was shutting off during the reset process of the gauges and is turned back on after an initial start procedure or sensor is not being properly reset during the same process.
    Registered User wbrownell9's Avatar
    Jun 2013
    New Castle, DE
    Had a '15 RT, started right off every time. Then it went through a period where it would crank with no result, but fire right up the second time. That lasted a while and it stopped, whether by software update or magic I have no idea. I can't really say exactly when it stopped, I just noticed one day it wasn't doing it anymore and hadn't for some time. I remember talking to someone at the Square Route Rally about it (his GS was doing the same thing) and it had stopped by the time I took it on vacation in September.
    2016 R1200 GSA
    Quote Originally Posted by wbrownell9 View Post
    Has anyone have this go away and not come back? Seems to be common problem or maybe just a boxer characteristic! Good thing is it always always starts on second crank. I'm going for service this summer but has anyone had a dealer recognize and diagnose it ?
    Registered User donmoe's Avatar
    Dec 2014
    Jupiter, Florida
    I have noticed that my 2015 R1200GSA will consistently start by just hitting the starter button when I do not advance the throttle. However, when I inadvertently do advance the throttle even slightly as I press the starter button, as I am accustomed to doing on my other bike, the engine consistently does not start up, but just continues cranking. When I then let loose of the throttle grip and hit just the starter button, the engine fires up immediately.
    Don
    2015 BMW R1200GSA.......2008 Kaw Concours 14......1974 Kaw Z1
    2013 Triumph Trophy SE....2004 BWM R1150RT..........1973 Kaw H1
    2010 Kaw Concours 14......1981 Kaw KZ1000
    Nope!
    Judging from what I've read, this has been an issue on quite a number of WC since they came out in 2013.
    I recall seeing one of those light blue GS WC at a local dealer multiple times for that issue and a consistently noisy decompression valve.
    The tech tried everything and couldn't resolve the starting anomaly. Eventually the bike went back to the manufacturer because of the 2 issues and an unhappy owner.
    I owned 2 WC, a GS and an RT. Both would start upon first stab of the button every time.
    Here's one thread from June '14 ADVrider
    http://advrider.com/index.php?thread...gsa-wc.984683/
    I wouldn't worry about it much, maybe it'll change in time.
    Registered User AKsuited's Avatar
    Jul 2009
    Southern Tier of New York
    That's what I do on my wethead GS and it starts right off every time.
    Harry
