berniematic
Thanks to the forum I now have spark. So - added gas. Again, bike is clean but has not run in 8 years. Right side carb drips/runs gas out of what looks like a overflow hole as fast as it can make its way down from the tank. I figure the float valve needle thing is stuck but I can't get the bowls off. They both hang up in one corner where it appears a tube / passage runs into the bowl. Found a schematic on the web but can't locate info on removing the bowls. Other threads discuss carb cleaning but nothing on this little problem. Advice appreciated.
